Electric Field and the Speed of a Proton
The discussion centers on calculating the speed of a proton moving in a circular orbit just outside a nonconducting spherical shell with a charge density of -2.26 µC/m³. The initial incorrect assumption was that the charge of the proton (q₀) equaled the total charge inside the spherical shell, leading to an unrealistic speed calculation of 10¹² m/s. Upon correcting this assumption, the speed was recalculated to be on the order of 10⁵ m/s, which is a realistic value. This highlights the importance of accurately defining charge variables in electrostatic problems.
  • Understanding of electrostatics, specifically Gauss's Law
  • Familiarity with centripetal force and acceleration concepts
  • Knowledge of electric field calculations and charge density
  • Basic algebra for manipulating equations in physics
  • Study Gauss's Law and its applications in electrostatics
  • Learn about centripetal motion and its relationship with electric fields
  • Explore the concept of charge density and its effects on electric fields
  • Practice problems involving electric fields and particle motion in circular orbits
Students studying physics, particularly those focusing on electromagnetism and particle dynamics, as well as educators looking for examples of common mistakes in electrostatic calculations.
Ithryndil
A particle with a charge of -60.0 nC is placed at the center of a nonconducting spherical shell of inner radius 20.0 cm and outer radius 34.0 cm. The spherical shell carries charge with a uniform density of -2.26 µC/m3. A proton moves in a circular orbit just outside the spherical shell. Calculate the speed of the proton.
We will need:
E = F/q_{o}
\Phi=EA=q_{inside}/\epsilon_{o} (no integral is needed because we know the electric field will be constant at the surface of the sphere and we know the surface area of a sphere).
F = ma_{c}
Solving for E I get:
E = q_{inside}/(\epsilon_{o}A)
q_{o} is just the inner charge (-60.0nC) + the outer charge [4/3*pi*charge density*(0.34^3-0.20^3).
Plugging in for E I get:
F/q_{o}=q_{inside}/(\epsilon_{o}A)
q_{o} = q_{inside} because the spherical surface should act as a point charge right?
Therefore after some algebra and substitution for the centripetal acceleration I get:
v = \sqrt{q^{2}/(4\pi\epsilon_{0}rm})
Where r = .34 and m is the mass of a proton.
When I plug in all the values I get a speed on the order of 10^{12}m/s
Which is faster than the speed of light if I am not mistaking...that being roughly 3 x 10^{8}m/s
What am I doing wrong?
My problem lies with the above. q_{o} = q_{inside}. That is a false statement. The q_{o} is actually the charge of the proton, not the charge of the entire charge configuration. With that adjustment I get an answer on the order of 10^5 which is must more realistic and was the correct answer.
Yup that's right. Good that you figured it out by yourself.
  • · Replies 26 ·
  • · Replies 17 ·
