Electric Field due to an Infinite Line
The electric field due to an infinite ribbon of charge can be calculated using the formula E = σ/2ε, where σ represents the surface charge density. In this case, the surface charge density is given as σ = 2 x 10-6 C/m2. To find the electric field at a point 2 cm from one edge of the 2 cm wide ribbon, the ribbon should be divided into infinitesimal strips of thickness dx, allowing for the application of the linear charge density concept.
  • Understanding of electric fields and charge distributions
  • Familiarity with the concept of surface charge density
  • Knowledge of calculus, specifically integration of infinitesimal elements
  • Basic principles of electrostatics, including Gauss's Law
  • Study the derivation of the electric field from an infinite line charge
  • Learn about the application of Gauss's Law in calculating electric fields
  • Explore the concept of surface charge density in electrostatics
  • Practice problems involving integration of electric fields from continuous charge distributions
Students studying electromagnetism, physics educators, and anyone seeking to understand electric fields generated by continuous charge distributions.
SalsaOnMyTaco
Recalling that the field due to an infinite line charge with Charge-per-unit-lenght λ is
E=λ/2∏εx
At distant x from the line, find the field due to an infinite "Ribbon" of charge 2cm wide, at point 2 cm from one edge in the plane of the Ribbon. The surface charge density on the Ribbon is σ=2x10-6C/m2.
Note: Linear charge density on width dx of the ribbon is σdx
E=σ/2ε
I am lost and I am not sure how to start the problem :confused:
Break the ribbon into strips of infinitesimal thickness dx.
