Electric field inside and outside a sphere (Not Gauss)
4 replies · 5K views
Waxterzz
Find E(r) inside and outside a uniformly charged spherical volume by superposing the electric fields
produced by a collection of uniformly charged disks.
a+b) Given equations, sketch of problem
This is the equation in the handbook for a disk (but in the exercises the z becomes x, without loss of generality)
So by varying theta, he wants you to superpose the disks, to form a solid sphere. The disks are x- R* cos(theta) removed.
[/B]
So he changes in the equation for the disk,the nominator z was the distance from the evaluation point to the center of the disk, this was z. This now becomes x-R*cos(theta). The denominator was the distance from the rim of the disk to the evaluation point, this was in the equation just the pythagoras rule, now it varies with theta because you have a superposition of different disks, so the pythagoras rule becomes the cosine rule. I kinda get these alterations.
What I don't get:
But I don't really get how he substitutes the surface charge density with this term with rho in? The term d(surface charge charge) = rho * R * sin (theta) * d(theta)
If anyone wants to clarify this to me, thanks in advance.
I think the solution is just wrong because the last step isn't correct?
Edit:
Looks like the solutions manual from Zangwhil contains errors.
This is from a site I found on the internet (check problem 4d)
https://pa.as.uky.edu/sites/default/files/Phy416G-HWSol4.pdfbut now
dσ = 2πρR sin θdθ
and I still don't know how to do that.
Hello. I don't see a mistake in the solution given in your first post. Can you state more explicitly where you feel a mistake has been made?
but now
dσ = 2πρR sin θdθ
I think this is incorrect. The factor of 2π should not be there.
In general, consider a thin slab of material of thickness d that has a uniform volume charge density ρ. If you approximated this by a surface with an "equivalent" uniform surface charge density σ, how would you write σ in terms of ρ and d?
For one of the thin disks of the sphere, how would you write the thickness |dx| of the disk in terms of R, θ, and dθ?
TSny said:
Hello. I don't see a mistake in the solution given in your first post. Can you state more explicitly where you feel a mistake has been made?I think this is incorrect. The factor of 2π should not be there.In general, consider a thin slab of material of thickness d that has a uniform volume charge density ρ. If you approximated this by a surface with an "equivalent" uniform surface charge density σ, how would you write σ in terms of ρ and d?
Excuse me sir, for the late reply. I think I didn't understood it first, then forgot about it, now I stumbled across it and still haven't figured it out
ρ . A . d = σ . A
ρ . dx = σ
Is this what you were implying?I don't see how R sin θ dθ equals the thickness of my disk, since R sin θ points in the direction perpendicular to the x-axis.
http://blob:https://imgur.com/7c67520c-b11f-4fb3-9218-afcca75d1bf7
Waxterzz said:
ρ . A . d = σ . A
ρ . dx = σ
Yes.
See if the following diagram helps. The red line in the right figure indicates the thickness of the disk. Note that the red line is also the base of a small right triangle at the top of the disk where R dθ is the hypotenuse. See if you can find the length of the red line by using trig on the right triangle.
