Electric field magnitude problem
27 replies · 4K views · last reply
gracy
The electric potential existing in space is V(x,y,z)=B(xy+yz+zx).Find the expression for the electric field at point P(1,1,1) and it's magnitude if B=10 S.I unit.
https://www.physicsforums.com/attachments/91091
3. The solution
I actually do have the solution of problem,but I have many doubts regarding the solution.
So want to list them and have them resolved.The solution is
http://images.thedigilibrary.com/notes/courses/IPROFPHenC18T01ST01.ILLUS.1P.pdf
page no 36 to 38.
For those who(their computers :wink:)could not open this pdf and so you don't have to scroll down all the way up to page 36
Screenshot of a textbook solution page showing the formula E = -dV/dr extended to E = -[i (dV/dx) + j (dV/dy) + k (dV/dz)], with the partial derivatives explained and the start of E = iEx + jEy + kEz.
Screenshot of a PDF page showing partial derivative formulas: Ex = -∂V/∂x, Ey = -∂V/∂y, and Ez = -∂V/∂z, followed by the text "In the question".
Worked solution showing V = B(xy + yz + zx), Ex = -dV/dx = -B(y + z), then Ex = -10(1 + 1) with B = 10 and (x, y, z) = (1, 1, 1).
Handwritten-style worked solution showing Ey = -20 N/C and Ez = -∂V/∂z = -B(x + y), with a partially visible earlier line above.
Handwritten-style worked solution showing E = -20 N/C components, E = (-20i - 20j - 20k) N/C, and magnitude sqrt(Ex^2 + Ey^2 + Ez^2) = 20 sqrt(3).
Query: I will mention one ,by the time it gets resolved I will mention second ...
V=B(xy+yz+zx) why?According to the question V(x,y,z)=B(xy+yz+zx)
Where did (x,y,z) go?
Are you asking why the potential V doesn't have x,y,z components? Remember that potential is a scalar value, not a vector.
V(x,y,z) is notation that indicates that the quantity V is a function of the coordinates x, y, and z. Often, the notation is shortened to just V where it is understood that V depends on (x, y, z). It's similar to what you saw in algebra class where you might have a function y = mx + b which you could also write as y(x) = mx + b where y(x) indicates that y is a function of x.
[ ATTACH=full]91091[/ATTACH]
3. The solution
page no 36 to 38.
[ ATTACH=full]91095[/ATTACH]
[ ATTACH=full]91096[/ATTACH]
[ ATTACH=full]91097[/ATTACH]
[ ATTACH=full]91098[/ATTACH]
[ ATTACH=full]91099[/ATTACH]
V(x,y,z) = B⋅(xy+yz+zx) is simply saying that the electric potential, V, is a function of x, y, and z. and at some point, (x,y,z), V is given by the formula indicated.
They merely left off the x, y, and z .
When we should use extended form of formula of electric field and when we shouldn't?
You need the extended form to calculate the components of the electric field, which is a vector, term by term.
##V## is the value of the function.
##V(x,y,z)## is the function.
They replaced the function with the value of the function.
Suppose you had ##V=f(x,y)=x^2-y##.
##f## is the function, ##V## is the value of the function. It is common practice to sloppily interchange the function with the value of the function.
In this example let's say ##V## is the electric potential. If you give me the values of ##x## and ##y## I can tell you the value of ##V##. For example, if ##x=2## and ##y=1## then ##V=3##.
The function ##f## is not the electric potential ##V##. It's a recipe that that tells me how to find the value of the electric potential ##V## given the values of ##x## and ##y##.
Unfortunately, the authors of physics textbooks take the liberty of interchanging these two things, treating them as though they are the same when they are in fact different. In this case what they are doing is using ##V## as the value of the function, but also telling you that the value of ##V## depends on the values of ##x##, ##y##, and ##z##.
V=B(xy + yz + zx)
So,
##Ex##=##-dV##/##dx##
=– B(y + z)
I did not understand this part.
The problem appears to be saying that the variables V,x,y,z can be assigned values that are consistent with V=B(xy+yz+zx), where B is just another real number, not a function. So we have
$$\frac{\partial}{\partial x} V=\frac{\partial}{\partial x} B(xy+yz+zx)=B\frac{\partial}{\partial x}(xy+yz+zx).$$
How you came to know that B is just a real number?
The main reason is that if it isn't, the correct way to start is
$$\frac{\partial}{\partial x} V=\frac{\partial}{\partial x} B(xy+yz+zx)=B'(xy+yz+zx)\frac{\partial}{\partial x}(xy+yz+zx).$$ Also, the problem statement includes the words "if B=10", and the solution includes the words "given B=10". It doesn't look like they're talking about a function there.
Could you please tell me while taking derivative with respect to a variable when to take constant out and when to take derivative of constant=0?
In place of
##Ex##=##dV##/##dx##
There should be
##Ex##=##dV(x,y,z)##/##dx##
Right?
It's clear from the context, as Fredrik pointed out. The problem is poorly worded:
A better way to state it:
The electric potential existing in space is V(x,y,z)=B(xy+yz+zx) where B is a constant whose value is 10 in SI units. Find the expression for the electric field at point P(1,1,1) and it's magnitude.
Or better yet ...
The electric potential V=B(xy+yz+zx) where B is a constant whose value is 10 in SI units. Find the expression for the electric field at the point (x,y,z)=(1,1,1) and it's magnitude.
Since this is a worked example, the meaning can be determined from the context of the solution.
They call it the extended form, but I prefer to call it the more general form.
##\vec{E}=-\vec{\nabla}{V}=-\hat{i}\frac{\partial}{\partial x}V-\hat{j}\frac{\partial}{\partial y}V-\hat{k}\frac{\partial}{\partial z}V##, where ##\vec{E}=\hat{i}E_x+\hat{j}E_y+\hat{k}E_z##.
If we have a case where ##\hat{j}\frac{\partial}{\partial y}V=\hat{k}\frac{\partial}{\partial z}V=0##, in other words ##E_y=E_z=0##, and
##E=|E_x|=|-\frac{\partial}{\partial x}V|##.
I'm not sure where you are in your education, Gracy. It's confusing me. This is a Calculus I question whereas the math you're encountering in this thread is usually treated in Calculus III. What course are you taking right now that has prompted you to start this thread?
Look at the rules for taking the derivative of a sum. If you're taking the derivative of a variable plus a constant, you get the derivative of the variable plus the derivative of the constant. The derivative of a constant is always zero.
Look at the rules for taking the derivative of a product. If you're taking the derivative of a constant times a variable, you get the constant times the derivative of the variable.
I think you are not retaining these simple rules, so when you encounter more difficult situations you are getting lost. I recommend that you go back over the rules for taking derivatives and practice them.
You need to use the product rule (fg)'=f'g+fg'. If f happens to be a constant function, then f'=0 and we can use that to simplifiy the right-hand side to fg'.
gracy said:
And what about post#15?
You have a sign error. See Post #17. Otherwise either of your expressions is valid.
The notations ##\frac{\partial V}{\partial x}## and ##\frac{\partial V(x,y,z)}{\partial x}## are both acceptable. I would say that the V in the former former expression is the variable that occurs in the equation V=B(xy+yz+zx), and that the V in the latter expression is the function defined implicitly by that equation.
Regardless of notation, only functions have derivatives (variables do not), so the former expression can't be interpreted as a partial derivative of the variable. It must be interpreted as a partial derivative of the function.
You need a minus sign, since the relationship between E and V is ##\mathbf E=-\nabla V##.
(I wrote this before I saw that Mister T had already replied).
That's confusing. If we have ##y=f(x)## then ##y## is a variable and ##f## is a function.
We can write ##\frac{dy}{dx}=\frac{d}{dx}f(x)##.
It appears to me that on the left-hand side of that equation we have the derivative of a variable. On the right-hand side we have something that we call "the derivative of a function" but I'm not sure if that's a proper way to say it, strictly speaking, because one could argue that it's ##\frac{df}{dx}## that's the derivative of a function. I'm not a mathematician and have only an undergraduate minor in the topic. As a physics major, though, I was exposed to lots more math taught to me by mathematicians, but I spent a lot more time doing math in physics classes, and "learning" it from physicists.
Right. You could also say that the symbols x,y and f are all variables, and that the difference is that f is assigned values from the set ##\mathbb R^\mathbb R## (the set of functions from ##\mathbb R## into ##\mathbb R##), while x and y are assigned values from the set ##\mathbb R##.
The derivative of a differentiable function f is defined as the function f' such that
$$f'(x)=\lim_{h\to 0}\frac{f(x+h)-f(x)}{h}$$ for all ##x\in\mathbb R##. The derivative of a variable is undefined. It would be weird to define it, since a variable is just a symbol in the language we use to talk about mathematics. When we say "the derivative of f", we're actually talking about the derivative of the thing represented by the variable f. So what would "the derivative of y" be? The derivative of a real number, or the derivative of a letter in the alphabet?
An equation like ##y=3x^2## is a constraint on the values we can assign to x and y. If we choose to assign a value to x, then the constraint assigns a value to y. This means that the constraint implicitly defines a function. So we can define the notation dy/dx even though y isn't a function, by saying that it represents the value at x of the derivative of the function defined by the constraint. If the constraint is y=f(x), then that function is equal to f. So dy/dx should denote the derivative of f, not the derivative of y.
My interpretation of a notation like ##\frac{d}{dx}3x^2## is "the value at x of the derivative of the map ##t\mapsto 3t^2## with domain ##\mathbb R##". Any expression of the form ##\frac{d}{dx}(\text{some expression involving }x)## can be interpreted similarly. This intepretation ensures that ##\frac{d}{dx}f(x)=f'(x)##. So it also ensures that if our value assignments to variables are constrained by the equation y=f(x), then we have ##\frac{d}{dx}y=\frac{d}{dx}f(x)=f'(x)##.
To me ##\frac{dy}{dx}## is read "the derivative of y with respect to x". Saying it "reads" one way, and saying it "denotes" another way would be a pedagogical nightmare. Glad I don't have to teach it!
So,we can write like this
##V(x,y,z)##=##B(xy,yz,zx)##
##Ex##=##-dV(x,y,z)##/dx
I would just read it as "dee-why, dee-ex". But I would read ##\frac{d}{dx}x^2=2x## as "the derivative of x2 is 2x", even though this is an abuse of terminology. (Since x2 is a number, not a function, it would be more accurate to say that the derivative of the function f defined by f(x)=x2 for all x is the function g defined by g(x)=2x for all real numbers x. But who wants to talk like that?).
One thing that's especially confusing is that even though f(x) (the thing represented by that notation) isn't a function, the notation f(x) can be said to be a "function of" x, since its value is determined by the value assigned to x. The thing that's a "function of" something isn't even a mathematical object. It's a notation that represents a mathematical object, and that object is typically a number, not a function.
Yes, that's OK. But since the left-hand side of the second equation is written as ##E_x## rather than as ##E_x(x,y,z)##, I would prefer to write V instead of V(x,y,z).
Edit: I agree with Mister T that you should use ##\frac{\partial}{\partial x}## instead of ##\frac{d}{dx}##.
No, that would be confusing and, technically, wrong. If the value of ##V## depends on the values of ##x##, ##y##, and ##z## then taking the derivative with respect to ##x## will not give you ##\text{-} E_x##. You have to take the partial derivative with respect to ##x## to get the x-component of ##\vec{E}##.
$$E_x=-\displaystyle \frac{\partial V}{\partial x}$$
People write ##V(x,y,z)## simply to emphasize that the value of ##V## depends on the values of ##x##, ##y##, and ##z##. More in the way of a warning, or hint, about the right way to think about ##V##. So if I tip you off with my notation that ##V## depends on all three independent variables, and then tell you to take the full derivative to get ##E_x##, I'm steering you towards an error.
On the other hand, if ##V## depends only on ##x## then you might see
$$E_x=-\displaystyle \frac{dV}{dx}.$$
You ask some good questions, Gracy. They remind us that as teachers what we ask our students to do isn't stuff that just follows from our explanations, however lucid they might be. It takes practice applying it before the meaning has any chance of being clear. So, thank you for that.
