Electric field outside a long cylindrical shell
The discussion focuses on calculating the electric field outside a long cylindrical shell with a uniform surface charge density of 4.60E-6 C/m² and a radius of 12.3 cm. Using Gauss's law, the correct approach involves recognizing that the electric field (E) is determined by the charge (Q) on the cylinder and the area (A) through which the field is calculated. The formula E = Q/(A*ε₀) is applied, where ε₀ is the permittivity of free space. The participants clarify that the distance used in calculations should be from the center of the cylinder, not the radius.
  • Understanding of Gauss's Law
  • Familiarity with electric field calculations
  • Knowledge of charge density concepts
  • Basic geometry of cylindrical shapes
  • Study the application of Gauss's Law in different geometries
  • Learn about electric fields generated by cylindrical shells
  • Explore the concept of charge density and its implications
  • Investigate the differences between electric fields of infinite planes, cylinders, and spheres
Students and educators in physics, particularly those focusing on electromagnetism, as well as anyone seeking to understand electric fields in relation to charged cylindrical objects.
MeMoses
A long cylindrical shell of radius R = 12.3 cm carries a uniform surface charge 4.60E-6 C/m2. Using Gauss's law find the electrical field at a point p2 = 16.5 from the center of the cylinder.
EA=q/epsilon0
This is what I thought would work but does not produce the answer. The area is arbitrary I believe so I just used a 1m strip of the cylinder, A=2*0.123m*1m=0.246,**2. Q is found by multiplying the area of the cylinder by the charge density, Q=2*pi*r*1*(density)=3.555*10**-6 C. Solve for E, E=Q/(A*epsilon0) =0.163*10**6 N/C which is not correct. Any help would be great, especially if its before 11pm EST tonight.
Hi MeMoses! :smile:
Difficult to tell without seeing your intermediate steps …
but did you use r = 16.5 ?
i don't believe r=16.5 is needed, we just need to know that it is outside the cylinder, since it is an infinitely long cylinder the field should not be dramatically affected by distance. I think i just calculated area wrong
MeMoses said:
… since it is an infinitely long cylinder the field should not be dramatically affected by distance.
that works for an infinite flat plate, since the field lines can't get any further apart as they go away …
but they do get further apart from a cylinder, don't they? :wink:
Yup compare the lines for a plane, cylinder/wire and sphere to see how their spacing varies with distance from the object.
Ok that makes sense now. I feel like an idiot for think that. However, just to clarify, would the equation I need simplify as such, E*A=Q/epsilon -> E(2*pi*r*h)=Q/epsilon, and Q=(2*pi*r*h)*charge density? and would every r here be the distance from the center, not the radius of the cylinder as I previously thought?
Ok i got, thanks for the help
Good job!
  • · Replies 16 ·
