Electric field work physics problem
The discussion centers on the physics of electric fields and the work done by conservative forces on point charges. It establishes that the work done (W) is calculated using the formula W = -q*deltaV, where q represents the test charge and deltaV is the potential difference. It clarifies that electric potential (V) in a non-uniform field is independent of the test charge, while electric potential energy (PE) is dependent on both the magnitude and sign of the charge. The conversation concludes that when a negative charge moves towards lower electric potentials, the work done by the conservative force is negative, indicating that work is done against the conservative force.
  • Understanding of electric fields and forces
  • Familiarity with the concepts of electric potential and electric potential energy
  • Knowledge of the formulas W = -q*deltaV and PE = Vq
  • Basic principles of conservative forces in physics
  • Study the implications of electric potential in non-uniform fields
  • Explore the relationship between electric fields and work done on charged particles
  • Investigate the conservation of energy in electric fields and its applications
  • Learn about the behavior of charged particles in uniform electric fields
Physics students, educators, and professionals interested in electromagnetism, particularly those focusing on electric fields, potential differences, and the behavior of charged particles in electric fields.
Gear300
For point charges within an electric field, the natural direction a point charge takes in respect to a field would be towards lower potential energy, whereas the work done by the conservative force should be positive. So then, by W = -q*deltaV, do they refer to the magnitude of the test charge q? If deltaV was negative, it indicates that positive work was done...but if the charge is negative, the work becomes negative.
I'm not sure if I'm answering your question but W= -qEd which is equivalent to the change in potential energy in a UNIFORM field only.
The potential difference can be solved for using W= -Vq this is the amount of work it takes to move the test charge from a point a to point b say in between two plates
The electric potential V in an non uniform field does not depend on the test charge and its formula is then V=KQ/R
Electric potential energy on the other hand is defined as PE= Vq and does depend on the magnitude of the test charge and its sign.
In sum remember that Electric Potential does not depend on q; but that Electric Potential Energy (PE) does depend on q.
I see...but then in that sense -deltaU = W done by conservative force and deltaU/q = deltaV. That implies that -deltaV*q = W done by conservative force. For any particle in respect to a conservative force, its movement is towards less potential energy, which should also result in a decrease in electric potential (making deltaV negative). If W = -q*deltaV, then doesn't that imply that if an electron was naturally moving due to an electric force, W would be negative, whereas conceptually the actual work done by the conservative force should be positive?
An electron moves towards a higher potential. Electric potential is defined as the potential energy of a positive test charge.
wait a minute...you're right. So if deltaV is negative and q is negative, deltaU is positive...which means work was done against the conservative force, whereas, the conservative force does negative work in this case. So can we make this generalization?: If a negative charge is brought towards lower electric potentials, then the work done by the conservative force is negative.
yes. If you exchange the sign of all charges and potentials, all the forces and energies should come out the same.
Work in an electric field
When a charged particle passes between two parallel plates connected to a voltage source, the particle is accelerated toward one of the plates by the field. Assuming that the particle continues on its way without contacting either plate, how is the work done on the particle "paid back"? Is there a mechanism that reduces the field strength E by delta E that requires a current through the voltage source to restore the field to E? If so, what is the mechanism? If not, how is the work accounted for?
thanks-
Eric
If The particle picks up speed between the plates, it must have started at a higher (or lower for a negative particle) potential. If the particle is shot between the plates from far away (where the potential is very close to 0) and then flies off again to a far away point, the field can't have done any work on it.
Could you say that any particle that is accelerated in an electric field must have started from a higher potential, so that no work may be done by an electric field on any particle that is accelerated in the field?
  • · Replies 22 ·
