How Do Electric Fields Behave at the Center of a Charged Triangle?
The discussion centers on calculating the electric field strength at the center of an equilateral triangle formed by three charged rods, specifically two charged at +10 nC and one at -10 nC. The correct electric field strength at the center is established as 1.08 * 10^5 N/C. The formula used for calculating the electric field strength from a charged rod is Q/(4*pi*e_0*r*sqrt(r^2 + (L/2)^2)), where e_0 is 8.85*10^-12. The user initially miscalculated by incorrectly summing the components of the electric fields from each rod.
  • Understanding of electric fields and their calculations
  • Familiarity with Coulomb's Law
  • Knowledge of vector addition in physics
  • Basic concepts of electrostatics
  • Study the derivation of the electric field formula for charged rods
  • Learn about vector components in electric field calculations
  • Explore the concept of superposition in electric fields
  • Investigate the effects of different charge distributions on electric fields
This discussion is beneficial for physics students, educators, and anyone interested in electrostatics, particularly those studying electric fields and their behavior in geometrical configurations.
beatbama85
Here's my problem:
Three 10-cm-long rods form an equilateral triangle. Two of the rods are charged to + 10 nC, the third to -10 nC. What is the electric field strength at the center of the triangle?
Answer in back of book: 1.08 * 10^5 N/C
By looking at the corresponding section, it gives the formula for the electric field strength in the plane that bisects a charged rod as:
where e_0 is given to be 8.85*10^-12.
I thought that you would add the vertical and horizontal components of the 3 electric fields in the center due to each rod to get the net electric field. After some calculations, I get that the final answer should be 2 times the formula I gave above, but this does not give me the correct answer. What am I doing wrong? Please respond, thanks!
Nevermind, I got it.
  • · Replies 16 ·
