Electric fields two point charges
The discussion centers on calculating the point where the electric field is zero due to two point charges, q1 = -6q and q2 = +3q, separated by a distance d. The user attempted to solve the equation 0 = E1 + E2, leading to the quadratic equation x^2 - 2dx - d^2 = 0. The solution yielded two potential points, but only one is valid where the electric field vectors oppose each other, resulting in a net electric field of zero. The user was advised to correctly reference the origin at q1 when measuring x from the other charge.
  • Understanding of electric fields and point charges
  • Familiarity with the equation E = kQ/x^2
  • Knowledge of solving quadratic equations
  • Ability to interpret vector directions in electric fields
  • Review the principles of electric fields from point charges
  • Study the quadratic formula and its applications in physics problems
  • Learn about vector addition in electric fields
  • Explore the concept of electric field lines and their implications
Students studying electromagnetism, physics educators, and anyone solving problems related to electric fields and point charges.
mussgo
i just need to get this question over with
i tried and tried but i couldn't get the right answer plss anyone u.u
1. Homework Statement
point charges q1 = -6q and q2 = +3q are separated by distance d. Locate the point (measured from the origin at q1) at which the electric field due to the two charges is zero.
<img src=http://www.webassign.net/hrw/23_30.gif>
2. Homework Equations
E=kQ/x^2
3. The Attempt at a Solution
well i did 0= E1+E2
i got this
0 = 3kQ/x^2 - 6kQ/(x+d)^2
6kQ/(x+d)^2 = 3kQ/x^2
cross multiplied
2x^2 = x^2 + 2dx + d^2
x^2 - 2dx - d^2 = 0
and then i did quadratic formula and got d-+d(sqrt2)
like 2.414d and .414 but as i put them in the webassign i got em wrong
can anyone help or tell what i did wrong or any feedback would be apreciated u.u
There is only one point where the charges cancel each other out. It is one of the two you have calculated for, but only one has the E field vectors pointing opposite directions, which give a net charge of zero.
but something must be wrong because like i said earlier
the webassign says its wrong :S u___U
> got this
You origin is given at q1 = 6q, but you are measuring x from the other charge.
true :O
im going to try it
and see what comes out :O
  • · Replies 32 ·
