Electric force acting on an electron
The electric force acting on an electron can be calculated using the equation F=ma, where the acceleration is given as 5.4 x 10^3 m/s². The correct calculation yields a force of 8.64 x 10^-16 N. While the fundamental charge of 1.60 x 10^-19 C was mentioned, it is not necessary for this calculation since the mass of the electron is required to find the force directly. The discussion emphasizes that using the electric field strength (E) is inappropriate without knowing its value.
  • Understanding of Newton's second law (F=ma)
  • Knowledge of the mass of an electron (9.11 x 10^-31 kg)
  • Familiarity with electric force concepts
  • Basic understanding of electric fields and charges
  • Research the mass of an electron and its implications in electric force calculations
  • Learn about electric field strength and its relationship to force
  • Study the effects of gravitational and magnetic fields on charged particles
  • Explore advanced topics in electromagnetism, such as Lorentz force
Students in physics, educators teaching electromagnetism, and anyone interested in understanding the forces acting on charged particles like electrons.
1126
An elctron moving through an electric field experiences an acceleration of 5.4 x 10^3 m/s^2. Find the electric force acting on the electron.
I think the equation F=ma may be used and maybe E=F/qsubo Do I need to use the fundamental charge to find an answer? using the fundamental charge of 1.60x10^-19.
My attempt at a solution is:
F=ma
F=(5.4x10^3)(1.60x10^-19)
F=86.4x10^-16 N/C
is that correct? The fundamental charge was not given in the question. Is this even the correct way to find the solution?
F=ma
F=86.4x10^-16 N/C
You have multiplied an acceleration by a charge and claimed the answer has unit N/C - and I think your answer should not be 86.4 x 10-16 perhaps just 8.64 x 10-16 - not that that is correct.
For a start, you were trying to find a force - so the units if the answer would be Newtons alone.
I don't think you need the fundamental charge, but I do think you need the electron mass.
Well, I'm finding the Electric Force which could also be E=F/q. Although, without any mass, I can't solve for F and put it into the equation. You were correct with the 8.64 x 10^-16, I simply calculated it incorrectly.
So, is the way I went about solving this equation correct?
Not really. E is the Electric Field Strength. Did you know the size of the Electric Field Strength?
F = ma seems a much better idea.
I do not know the size of the Electric Field strength. :/ that's why I resorted to the fundamental charge of 1.60 x 10^-19.
I was suggesting that trying to use any formula that involves the Electric Field Strength (E) is not a good idea for the exact reason that you don't know its value.
Perhaps you were distracted by the word Electric in the original question.
An electron may accelerate because is is near the Earth [we could expect 9.8 at best] due the effects of a Gravitational Field.
It may accelerate because it is placed in an electric field.
It may accelerate because it is moving through a magnetic field.
The reason it accelerates in this case is presumably because of an appropriately sized Electric field; but form there F = ma is all you need.
OH! That makes so much more sense! Thank you so much for explaining that! That was so helpful! I really appreciate it! :)
  • · Replies 25 ·
