Electric Force/ Electrical Fields
14 replies · 5K views · last reply
xswtxoj
How many electrons must be removed from each two of 5.81kg copper spheres to make the electric force of repulsion between them equal to the magnitude to the gravitational attraction between them
F: Ke (q1)(q2)/r^2
( 8.99x10^9)( 9.11x10^-31)(1.67x 10^-27)/ 2 (5.81)
= 3.97x 10^ -47
Maybe you should write out the variables for the equations and simplify before throwing the numbers in?
Besides I'm not familiar with what a 10-47 of an electron looks like.
i'm not sure wat to do? probably F=ma then F=Ke(q1)(q2)/r sqed
Gravitational force has its own expression,
http://www.physicsclassroom.com/Class/circles/u6l3c.cfm
If you're not familiar with it already.
And I suppose for the question that you neglect the mass being removed when you remove electrons? It's a very small mass, but still a mass.
Anyway, the way I understand the question is that the same amount of electrons is being removed from the spheres, which means one thing, which simplifies everything; the spheres will have the same charge.
You've got the expression for gravitational force and electric force. Relate them in the way the question asks you to.
(m)(a)=F then G=(m1)(m2)/d sqed? or F: Ke (q1)(q2)/r^2 or how would i use these?
As Hannisch suggests consider the gravitational force of attraction between two 5.8 kg masses.
That must equal the force of repulsion at the same distance - at whatever r because they are both proportional to 1/r2.
Set them equal and discard the terms that cancel. Then solve.
so do i start with F= 6.673x 10^-11 * 5.81/ d sq, but d sq cancels, but then (5.81) a= F, therefore 3.87x 10^-10 = F= (5.81) a, ?
No.
GMm/r2 = kqq/r2
The masses are equal. The charges equal.
q = m*(G/k)1/2
therefore is i solve for q, then (5.81)(( 6.673x 10^11/8.99x10^9)) ^1/2
wait if i plug in the equation u gave me then i get 2.15 x 10^-20
I haven't the slightest idea what you calculated.
But I am fairly certain you didn't calculate the square root correctly.
As an example (4*10-6)1/2 will yield 2*10-3
(5.81)(( 6.673x 10^11/8.99x10^9)) ^1/2 ----------> 6.673x 10^11/8.99x10^9)) ^1/2=8.61x 10^-11 then times 5.81 equals 5x 10^-10
G is 10-11 but you got the right number.
But what are your units?
