Automotive Electric go kart conversion. battery question?
  • Thread starter Thread starter dwaring28720
    Battery Electric
The discussion focuses on converting a go-kart to electric power using a 36V 800W e-scooter motor and whether three 12V car batteries can effectively power it. Participants clarify that the Cold Cranking Amps (CCA) metric is not suitable for determining battery capacity for this application; instead, amp-hours should be considered. Calculations show that three car batteries in series can provide approximately 5.4 hours of runtime at full load, but this does not account for peak current demands. It's also noted that using PWM circuits can enhance efficiency and runtime. Lastly, the importance of avoiding full discharge of batteries to prolong their lifespan is emphasized.
dwaring28720
electric go kart conversion. battery question!?
hi no idea if I've posted this in the right section, but i apologise now if it is, I've decided to do some tinkering with my retired kart basically I am pulling out the honda gx160 engine from my Honda pro kart and want to fit it with a "36v 800watt escooter motor"
http://www.ebay.co.uk/itm/36-VOLT-800-WATT-ELECTRIC-E-SCOOTER-MOTOR-36v-800w-/180761403629?pt=UK_Toys_Games_Outdoor_Toys_ET&hash=item2a163820ed <-- sorry if i am not meant to link things like this it was just for explanation purposes.
and basically my question is, can i run this motor at full using 3x car 12v battery, ie
http://www.ebay.co.uk/itm/12V-CAR-BATTERY-TYPE-063-4-YEAR-GTEE-/110572167954?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19be9d6312
as i may have got this calculation wrong but according to what i read you take the CCA "Cold Cranking Amps" and multiply this by 12.6 to get the watts, so the battery in question produces 400 CCA x 12.6 gives me 5040 watts and with 3 of them running in series to produce the 36v ... am i getting this right before i go out and buy bits that aint going to work
thanks in advance
I'm not too sure why you are using cold cranking amps here. If you are asking 'how long will these batteries power the kart for' then you should be looking for amp-hours. I'm also not too sure where you have this constant of 12.6 but the Watts provided to your circuit should follow basic Ohm's law (I=V/R)
if we rearrange this to;
P=I*V (power = volts multiplied by amps);
And because we know V=36v and P=800W then we can rearrange further to get the amps required from the batteries;
I=P/V (I = 800/36)
Amps drawn from the battery when the motor is at full 800W load will be 22.22 amps.
I know the battery in my car is rated at 40 amp-hours, multiply this by three to represent your system in series and we can supply 120 amps for an hour.
120/22.22 = 5.4 hours
So yes, three car batteries in a series circuit would power an 800W motor for 5.4 hours before they needed recharging.
Hope this helps.
thanks for your answer very clear and helpful, you even answered my next question of how long the batteries would last after a full charge, i came across the CCA figure when browsing elsewhere for a quick answer
http://wiki.answers.com/Q/How_many_watts_does_a_car_battery_produce
thanks very much for your help
Glad to be of help, good luck with your project.
I=P/V (I = 800/36)
Hope this helps.
I believe you may have confused series/parallel there: if the voltages add AND the current capacities add, then total energy availe would have gone up by 9 for 3 batteries...
In series, each battery will still only supply 40 amp-hours, and the voltages stack.
If you ran the batteries in parallel, you'd only have 12 volts available, but would then have the 3*40 = 120 amp-hours.
Each battery is capable of supplying 12V * 40 amp-hours = 480 Watt-hours of energy. 480*3 = 1440 Watt-hours total.
You will get approximately 40 amp-hours / 22.22 amps = 1.8 hours run time @ full load (Same as calculating 1440/800).
Note, this does not take into account starting current (locked rotor current), which will be several times higher than the 22 amps. (Hint: don't buy controller components rated to 25 amps)
CCA (Cold Cranking Amps) is a rating of what the battery can do for a very short time in cold weather (I think it's 1 minute) - you do not want to design to this, it's hard on the battery, and would yield a very short run. The 3*12.6volts*400CCA=15,120 Watts (20 hp) calculation is the peak power that you can draw from this setup.
Again, 400 amps may be somewhat...difficult/expensive to design for (in regards to your controller). Find the curves for the motor you want to use to get the max current it will draw.
As a tip, look into PWM (pulse-width-modulation) circuits for controlling the power you feed the motor; any other method will reduce your runtime (less efficient-creates more heat).
One more note (if you pick this project back up again): Batteries do not like to be run from full charge to full discharge - you will kill them rather quickly (unless you shell out for "deep-cycle" batteries). Something to keep in mind.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
