Electric/Magnetic field Inverse square
  • Context: Undergrad
  • Thread starter Thread starter superslow991
    Field Inverse Square
5 replies · 2K views
superslow991
Using magnetic field over electric field
no equation needed
THis may not make sense but did an experiment dealing with the inverse square law and we measured the magnetic field in this case. Want to know is there some type of difference between magnetic field and electric field where we would choose to use the magnetic field over the electric field? for the inverse square law?
[Note: Thread moved to general physics by a mentor]
on Phys.org
the inverse square law depends on the configuration of the source(s) of the field, only if there is one magnet or a concentrated charge will it hold up
Well we used 2 magnets but my teacher said we could perform the same experiment with just 2 charges and why were we not offered to use an electric fied than magnetic field in this case
electric charges are difficult to keep control over. they can easily leak away for instance if you come too close to the source spark over can occur. also if the humidity is high (as low as 60% relative humidity) even an insulator can conduct the charge away thereby weakening the source. magnets are quite stable and do not change that readily, so it is much easier to work with them rather than an electrically charged body.
could you maybe show us your results or a picture of your graph?
