Electric Potential: Calculating Energy & Power
9 replies · 2K views
alligrass
how much energy is wasted when 35 C of charge flow through a 120 V toaster in 5.0 S?
how much power?
work=qv i think...
power= work /time
i thought to find energy wasted i would find the work used. (?yes?)
so i guess that would be 35(120) whihc is 4200 J
so then do i power = 4200/5=840
is this correct?
well P = IV
and they give you the time...so you know the units of Power = (Joules/second), so given the time you can find the joules wasted...
both problems solved with one equation!
:D
wait i didnt really understand what u just said.
did i do this right or is it wrong?
no recheck your work and look at the formula I gave you and the units of power, energy is in JOULES, and power is in Watts or Joules/second...it should be straightforward from there
well a watt = J/sec
so i got energy in joules correct right??
then those Joules per 5 sec gives u 840 J/ a sec
ok another formula that will help is to know that I (current) is equal to (change in Q- the charge)/ (change in time - seconds), both of these informations are given in the problem...
once you find I...you can solve for P = IV, using the information given in the problem...
oh and I forget to mention that the change in potential difference (V) is equal to the potential-energy change per unit charge in moving across the toaster...so U = Vq...you know volts and know q so you can find the energy lost.
so isn't i=7
and then 7(120)=840...
ddint i do that in the proble, above?
ohh..lol my bad, yes your work is correct, sorry for the explanation again above...wasn't thinking so simply...
