Electric Potential, conducting sphere in a conducting shell
The discussion revolves around calculating the electric potential and charge distribution in a system consisting of a metallic sphere with a radius of 5.00 cm and a concentric conducting shell with an outer radius of 10.0 cm and a net charge of +20 mC. The potential at the center of the sphere is established as zero volts, leading to the conclusion that the sphere must possess a charge of -20 mC to maintain this potential. The participants utilized Gauss's Law and the relationship between electric field and potential to derive the charge on the sphere and the potential difference between the sphere and the shell.
  • Understanding of electric potential and electric fields
  • Familiarity with Gauss's Law
  • Knowledge of the relationship between charge and potential in conductors
  • Basic calculus for evaluating integrals related to electric potential
  • Study the application of Gauss's Law in electrostatics
  • Learn about electric potential and electric field relationships in conductive materials
  • Explore the concept of charge distribution in concentric spherical conductors
  • Investigate the mathematical derivation of electric potential from electric fields
Students and professionals in physics, particularly those focusing on electrostatics, electrical engineering, and anyone involved in solving problems related to electric fields and potentials in conductive systems.
fornax
The electric potential at the center of a (5.00cm radius) metallic sphere is zero Volts. The sphere is surrounded by a concentric conducting shell of 10.0cm outer radius and a thickness of 2.0cm. The shell has a net charge of +20mC. a.)Find the charge on the sphere. b.)Give V(r) and then plot V(r). c.) What is the Voltage between the conductors.
Outside: V = (1/4∏ε0)*(q/r)
Inside: V = (1/4∏ε0)*(q/R) (R being the radius of the sphere)
I'm honestly really lost with this one, and I was hoping to be pointed in the right direction. The thing that confuses me is that V at the center of the sphere is equal to V at the surface of the sphere. Working off of that, how can the sphere have a charge? Does this mean the net charge is located completely on the conducting shell? I feel like I'm missing something and I have this completely wrong. Thanks for your time reading this.
The static electric field is zero inside a metal. What can you say about the potential then? How are the electric field and te potential related?
The charge of a metal can exist on the surface only. The sphere has some charge on its surface. That charge will induce equal and opposite charge on the inner surface of the shell and there is charge also on the outer surface of the shell. Apply Gauss Law two find the electric field in the different domains. The charge of the sphere is obtained from the condition that its potential is zero.
ehild
Assuming the charge on the outer shell is distributed evenly, the outer shell gives no contribution to the E-field between the shell and sphere. If there is a voltage difference between the shell and sphere, then the sphere must be charged. However, not knowing the charge on the inner sphere, or the E-field inside or outside, or the voltage drop, I can't imagine a way you'd go about finding those things. I'd love to hear the actual solution to this problem when you find it out, or anyone else's ideas.
Some more hints:
The potential is a continuous function.
Outside the shell (r≥0.12 m) U(r)=(1/4∏ε0)*(q/r) where q is the charge confined inside the sphere of radius r. That contains both the charge of the shell, 20 mC, and the unknown charge Q of the sphere inside the shell.
Inside the metal shell, the potential is constant, so U(0.1)=(1/4∏ε0)*(q/0.12)
The potential between the metal sphere and the shell (0.05 m<r<0.1 m) depends on the charge of the sphere, and it must contain an additive term A (U(r)=(1/4∏ε0)*(Q/r)+A) so it matches the potential U(0.1)=(1/4∏ε0)*(q/0.12). The potential is constant inside and on the surface of the metal sphere: It is zero at r=0.05 m.
ehild
So I talked to my teacher today, and he told me that the electric potential of the sphere being 0 was a result of electric fields cancelling out. So going off of that, would it be safe for me to assume that the charge on the inner radius of the sphere would be -20mC? and going off of that, I could assume that the charge on the shpere would then be +20mC, cancelling the charge on the inner surface of the shell. Looking at it that way, it just seems to simple, I feel like I'm missing something.
New thought, since I know that v=0 at the surface of the sphere, could I use that in conjunction with VB-VA = A(integral)B E*dl and use that to find the voltage potential at the surface of the inside of the shell, and then maybe find the charge required there to counteract the v at the surface of the sphere...any guidance would be appreciated.
Er...I assumed the metallic sphere was conducting. The potential inside any conductor is constant, and it being 0 or not is just a matter of reference...
Fornax, you have the same problem in the other thread at Introductory Physics. See it.
ehild
I'll give Gauss's law a try and get back to you. Thanks for the hints, and the help!
fornax said:
I understand that the field is constant in a metallic sphere,
The electric field is zero in the metallic sphere.
ehild
ok so outside of the sphere I got the E = 20 +Q/4∏r2(epsilon)0
Inside I got that E = Q/4∏r2(epsilon)0
Ok so going off of that, since the v=0 on the sphere, that means that E is strongest at the shpere, and so, the E field must be flowing towards it. That being said, the sphere must then have a negative charge, so the inside of the shell has a positive charge. So the outside of the shell woud have a charge of -20mC, the inside would have a charge of +40mC, and the sphere would have a charge of +20mC.
E=20+20/4∏r20 = 3x10^13
E = Q/4∏r20 = 1.5x10^13
ok, good so far?
Use parentheses, and write Q in coulombs. Outside the shell E = (0.020 +Q)/(4∏r2epsilon0)
Why do you think so?
Using the expressions for the electric field, set up equations for the potential, and use the information given.
ehild
Well I figure the sphere is -20mC because electric fields flow towards negative charges. Since Electric potential's strength decreases as the electric field strength increases, and the electric potential at the surface of the sphere is 0, the sphere must have a negative charge. Based off of that, the charge on the inside of the shell must be positive, and twice the outside negative charge, since the shell's net charge is +20mC. I may be assuming too much here, let me know.
You are assuming too much. Why do you think that the charge of the sphere is -20 mC?
How are the potential and electric field related? How do you get the potential of a charged sphere?
ehild
Ok, so I think I may have it.
after using ΔV = -∫Edl
Outside shell : ΔV = (20+Q)/4∏ε0r
Inside shell : ΔV = Q/4∏ε0r
then
ΔV = (20+Q)/4∏ε0r
ΔV = 20/4∏ε0r + Q/4∏ε0r
-20/4∏ε0r = Q/4∏ε0r ----> multiply by 4∏ε0r
-20mC = Q
then
ΔV = ∏(20+Q)/4ε0r
-20mC = Q
ΔV is the potential difference between two points. Once you use it for two points outside the shell, the other time it is inside the shell. Can they be identical?
If they are identical it means that 20/4∏ε0r + Q/4∏ε0r = Q/4∏ε0r
This equation is equivalent to 20=0.
You got Q=-20 mC from the condition ΔV = 0. Potential difference between what points?
ehild
If the charge of the sphere is -20 mC, the net charge inside a Gaussian surface outside the shell is zero. The electric field would be zero, and the potential constant, the same as at infinity, that is zero. If the potential is zero at the outside of the shell, it is the same at the inner surface, as the potential is constant in a metal. If the surface of the inner shell is at zero potential and the sphere is also at zero potential, the electric field is zero in the cavity between the sphere and the shell. Zero electric field would mean zero charge on the sphere, which is contradiction. ehild
Ok, hopefully the last stab at this,
using Vb - Va =- Q / (4∏ε0) *[1/b-1/a]
20 - 0 = -Q / (4∏ε0) * [1/.08 - 1/.05]
20 = -Q / (4∏ε0*7.5) ---->multiply by -(4∏ε0*7.5)
-2.4x10^10 = Q
It is almost correct. Recalculate the potential on the left-hand side, using appropriate units and not forgetting 1/4∏ε0, which will cancel with the same factor on the right hand side. Also remember that the outer sphere contains not only the 20 mC charge but also the unknown Q. On the right-hand side, 1/0.08 -1/0.05=-7.5. But remember that the integral of 1/r^2 is -1/r, so the sign of Q will be really negative.
ehild
I merged the two threads.
Fornax, you had it right the first time. This problem belongs in the introductory physics forum. The advanced physics forum is for problems from upper-division classes and graduate classes.
Thanks for merging the threads, I hope I didn't confuse anybody :/ . As for another attempt, and yet again I think I have it...
(20 + Q)/(4∏ε0*7.5) - 0 = -Q / (4∏ε0) * -[1/.08 - 1/.05]
20 + Q / (4∏ε0*7.5) = -Q / (4∏ε0*7.5) ---->multiply by -(4∏ε0*7.5)
20+Q = -Q
20 = -2Q
Q = -10mC
Check the left hand side of the equation. What does 7.5 stand for?
ehild
To put things in order:
The potential at the outer surface of the shell at r=0.1 m is U(0.1)=k(Q+0.02)/0.1, where Q is the charge of the inner sphere.
The potential is constant on a metal, so the inner surface of the shell is at the same potential: U(0.08)= k(Q+0.02)/0.1
The surface of the inner metallic sphere is at zero potential. The electric field in the cavity is kQ/r^2. The potential difference between the inner surface of the shell and the small sphere at the centre is U(0.08)-0. The potential difference is also obtained as the integral of -E(r) in the cavity.
U(0.08)-0=\int_{0.05}^{0.08}\left(-k\frac{Q}{r^2}dr\right)=kQ(\frac{1}{0.08}-\frac{1}{0.05})
So Q is obtained from the equation
(Q+0.02)/0.1=-7.5Q.
  • · Replies 43 ·
