Electric potential energy problem
The discussion centers on a charged particle moving between two parallel plates with potentials V1 = -70.0 V and V2 = -50.0 V, separated by a distance of 2 mm. The particle, initially traveling at 90.0 km/s, is identified as a proton due to the direction of the electric field opposing its motion. The electric field strength is calculated as E = -10,000 N/C. The final kinetic energy can be determined using the work-energy principle, leading to the calculation of the particle's speed as it reaches the second plate.
  • Understanding of electric potential energy and electric fields
  • Familiarity with the concepts of kinetic energy and work-energy theorem
  • Knowledge of charged particles, specifically protons and electrons
  • Ability to apply equations related to electric potential differences
  • Study the relationship between electric field strength and force on charged particles
  • Learn how to apply the work-energy theorem in electric fields
  • Explore the differences in behavior between protons and electrons in electric fields
  • Investigate the implications of electric potential differences in practical applications
Students and educators in physics, particularly those focusing on electromagnetism, as well as anyone interested in understanding the dynamics of charged particles in electric fields.
demonelite123
A charged particle (either proton or electron) is moving rightward between 2 parallel charged plates separated by distance d = 2mm. The plate potentials are V1 = -70.0 V and V2 = -50.0 V. The particle is slowing from an initial speed of 90.0 km/s at the left plate.
a) Is the particle an electron or a proton?
b) What is its speed just as it reaches plate 2?
i used the equation V2 - V1 = -W_E / q (W_E is the negative of the work done by electric field). so i have 20 = -E(.002) and i got E = -10000 N/C. i don't know what to do next. how do i tell if its a proton or electron?
Note that the particle is slowing. What does this tell you about the direction of the force vector?
oh so that means the direction of the Electric field vector is opposite of the displacement vector so since the particle moves to the right the electric field points to the left. and since the particle is traveling the opposite direction the electric field is pointing at, does that mean it's an electron? i checked the answer in the book but it said it was proton though.
thanks for not helping me...
The electric field always points in the direction of the force on a positive particle. So if E is negative the force will reduce a positive velocity only if the particle is a positively charged proton. The problem with your reasoning is that the particle is not traveling opposite the electric field BECAUSE of the electric field. It was given an initial velocity by some divine methods ; ) Ever since then the Electric field has been trying very hard to convince the particle to travel in the same direction as itself. It's a subtle difference but it will really help you understand this stuff if you think the difference through.
Now, you've got everything you need for b):
W_{E} = \DeltaU = - \DeltaK
W_{E} = Fd = q_{e}Ed = q_{e}\DeltaV
K_{f} = K_{i} - q_{e}\DeltaV
Get the final KE and you're on your way to the finish...
  • · Replies 22 ·
  • · Replies 23 ·
  • · Replies 16 ·
