How Does Distance Affect the Work Done by an External Agent on a Charge?
The discussion centers on the work done by an external agent in moving a test charge in the presence of an electric field. It concludes that the absolute value of work done moving a charge from point B to C is greater than from point A to B, due to the differing distances and directions of force. The participants emphasize the importance of understanding the electric field's influence on work calculations, specifically referencing the equation W = Fd and the dependency of electric field strength on distance from the charge.
  • Understanding of electric fields and forces, specifically F = qE
  • Knowledge of work-energy principles, particularly W = Fd
  • Familiarity with the concept of absolute value in physics
  • Basic geometry related to distances in electric fields
  • Study the relationship between electric fields and work done on charges
  • Learn about the implications of uniform versus non-uniform electric fields
  • Explore the concept of potential energy in electric fields
  • Investigate the effects of distance on electric field strength using Coulomb's Law
Students studying electromagnetism, physics educators, and anyone seeking to understand the principles of work and energy in electric fields.
cy19861126
A positive charge of magnitude qo is shown in the diagram below. Points B and C are a distance r away from the charge and point A is a distance 2r from it.
1. Would the absolute value of work done by an external agent in moving the same test charge from point B to C be greater than, less than, or equal to from point A to B
2. Would the absolute value of the work done by an external agent in moving the same test charge from point A to C be greater than, less than, or equal to from point A to B?
W = Fd
1. Work from A to B to be would be negative because the distance is in the opposite direction of the force being exerted. From B to C would be 0 because the first half of the path has a negative work done and the second half of the path has a positive work being done. The absolute work done would be 0 because both paths have equal magnitude but different direction. Therefore, work from point B to C would be greater than from point A to B
2. I really have no idea about this problem. From A to C and from A to B are both negative, which makes the problem incomparable. All I know is that A to C has a longer distance than from A to B. However, I cannot compare their forces...
You don't know that. In order to be able to say that with certainty, you would have to have been told that there is a nonzero external electric field pointing from B to A. You weren't told anything like that.
Actually, I don't see how you can answer the question at all. If the field is zero, then it takes zero work to move the particle along any path (at constant velocity, that is). So let's assume that there is a constant, uniform external electric field. In that case then this problem becomes one of simple geometry. You know that F=q_0E is a constant, so you only have to determine which distance is greater when finding the absolute value of the work. And do note that the fact that they ask about the absolute value of the work allows you to disregard the sign of W.
So to answer the questions all you have to do is decide which path is longer.
How can the electric field be constant? E = k*(q/r^2) As you can see, electric field is dependent on the distance on the point charge
  • · Replies 22 ·
