Electric Potential questions and work done
4 replies · 4K views
jersey
+1.0uC
*-------3.0m---------*-----------3.0m---------*
A B
a) calculate the electric potential energy at A, 3.0m away from a point charge of +1.0uC.
b) calculate the electric potential energy at B, 6.0m away from a point charge of +1.0uC.
c) how much work would be done moving a +0.2uC charge between A and B?
d) which way would you be moving this smal charge if you were doing work against the field?
V=kQ/r
W-qV
a)
V=kQ/r
V= 8.99 x 10^9 x 1.0 / 3 = 2996666667N
b)
V=kQ/r
V=8.99 x 10^9 x 1.0 / 6 = 1498333333N
c)
W=qV
W= 8.99 x `10^9 x .2
W = 1798000000
d)
to the right.
I'm not sure if I'm on the right track, can anyone check and help me?
Firstly, the charge is 1μC (10-6 C) and you have used a value of 1
The formula is correct.
The answer is electric potential and this is measure in volts. You have stated N which means Newtons. (Force)
The formula is correct for the next part but for W=qV
V is the potential difference in volts between the two points, and q the charge you move.
You will have a value for V when you have got the answers to parts a and b.
HMm.. thank you.. is this better...
V=kQ/r
8.99 x 10^9 x 1.0x 10^-6/ 3
and
8.99 x 10^9 x 1.0 x 10^-6/6
for W=qV
= .2 x 10^-6 x 1498.3
=0.00029966N
Yes that's the correct answer for the 3rd part but the unit is joule (J) because you have calculated the work done.
In this case the field does the work on the charge.
Ok thankyou brilliant. I'm getting basics confused.
