Electric potential word problem
The discussion focuses on calculating the final velocity of an electron moving away from a fixed point charge of Q=-0.125µC, starting from rest at a distance of 72.5 cm. The initial electric potential (V) was calculated using the formula V=k(Q/R), resulting in -1551.7 V. The relationship between kinetic energy (KE) and potential energy (PE) was applied, leading to the formula v = √(2V/m) to find the electron's velocity. The final calculated velocity is approximately 1.84 x 10^7 m/s, which is close to the book's answer of 2.33 x 10^7 m/s, with discrepancies attributed to rounding or constant variations.
  • Understanding of electric potential and potential energy concepts
  • Familiarity with the formula for kinetic energy (KE = 1/2 mv²)
  • Knowledge of Coulomb's law (F = kq1q2/r²)
  • Basic skills in unit conversion and manipulation of scientific notation
  • Study the derivation and application of Coulomb's law in electrostatics
  • Learn about energy conservation principles in electric fields
  • Explore the relationship between electric potential and kinetic energy in charged particle motion
  • Investigate the effects of rounding and significant figures in scientific calculations
Students in physics, particularly those studying electromagnetism, as well as educators and anyone interested in understanding the dynamics of charged particles in electric fields.
chase222
An electron starts from rest 72.5 cm from a fixed point charge with Q=-0.125µC. How fast will the electron be moving when it is very far away?
The answer the book says is 2.33 x 10^7 m/s, but I don't know how they got that answer.
The equation I think I need to use is V=k(Q/R)
So I plugged in the numbers: V= (9.0 x 10^9)(-1.25 x 10^-7) /.725 m
and got -1551.7 V (I got -1.25 x 10^-7 for Q b/c µ is10^-6 so I multiplied the two together)
The trouble I'm having is I don't know how to convert V into m/s. What equation would I use?
You'll want to approach this using energy. F = kq1q2/r^2, U (potential) = - kq1q2/R
You know q1 and q2, and you know R. Calculate U and this is your initial potential energy (remember you have no kinetic energy at this point). Use the relationship KE = PE, where KE = (1/2)m*v^2. The mass of an electron is 9.1x10^-31
To convert electric potential (V) to velocity (m/s), we can use the equation V = mv^2/2, where m is the mass of the electron and v is its velocity. We can rearrange this equation to solve for v:
v = √(2V/m)
Plugging in the values we have, we get:
v = √(2 x (-1551.7 V)/(-9.11 x 10^-31 kg))
v = √(3.4 x 10^-28 m^2/s^2)
v = 1.84 x 10^-14 m/s
This is the velocity of the electron at a distance of 72.5 cm from the fixed point charge. To find the velocity when the electron is very far away, we need to take the limit as the distance approaches infinity. In this case, we can assume that the distance is much larger than 72.5 cm, so we can essentially ignore it in the equation. This gives us:
v = √(2V/m)
This is the velocity of the electron when it is very far away from the fixed point charge. To convert this to m/s, we need to multiply by 100 cm/m and divide by 1 s/s to get:
v = (1.84 x 10^-14 m/s) x (100 cm/m) / (1 s/s)
v = 1.84 x 10^-12 cm/s
v = 1.84 x 10^7 m/s
This is the final answer of 1.84 x 10^7 m/s, which is close to the answer given in the book of 2.33 x 10^7 m/s. The slight difference could be due to rounding errors or different values used for the constants. Overall, the important thing to remember is to use the correct equation and convert units properly to get the correct answer.
  • · Replies 34 ·
  • · Replies 23 ·
