How Does an Electrical Company Measure Energy Consumption?
  • Context: High School
  • Thread starter Thread starter gkangelexa
    Electrical Time
Electrical companies measure energy consumption using electricity meters that calculate total power based on voltage and current, following the formula P = IV. The total energy consumption is determined by multiplying power by the duration of use, measured in Kilowatt Hours (kWh). Modern metrology techniques utilize integrated circuits (ICs) like the Analog Devices ADE7768 and ADE7763, which sample current and voltage at high rates to compute instantaneous power and cumulative energy. This process replaces older methods that relied on mechanical spinning disks and counters.
  • Understanding of electrical power formulas (P = IV)
  • Familiarity with Kilowatt Hours (kWh) as a unit of energy
  • Knowledge of metrology principles in electrical measurement
  • Basic awareness of integrated circuits (ICs) used in energy measurement
  • Research the functionality and applications of the Analog Devices ADE7768 and ADE7763 ICs
  • Explore advanced metrology techniques for multi-phase circuits
  • Learn about the design and operation of modern electricity meters
  • Investigate the impact of smart meters on energy consumption tracking
Electrical engineers, energy analysts, and anyone involved in the design or implementation of energy measurement systems will benefit from this discussion.
gkangelexa
Electrical companies charge you based on how much energy you use ... So this means they first calculate the total Power based on the voltage they give each household and the current drawn... P = IV
but then they have to multiply the total power consumption times the time it is on in order to find the total energy consumption...
How can they know this data? How can they know how long a lightbulb or the television was on?
The device attached to your house or apartment is called an Electricity Meter. It is designed to measure how much power you use over time. Typically they measure this in Kilowatt Hours. One kilowatt of power use over one hour is one Kilowatt hour.
See here: http://en.wikipedia.org/wiki/Electricity_meter
This is called "metrology", and is at the core of electric power meters.
Typical ICs that can be used for metrology are the Analog Devices ADE7768 and ADE7763.
http://www.analog.com/en/analog-to-...rgy-measurement/ade7763/products/product.html
The IC samples the current and voltage of a single-phase circuit at a high sample rate (much higher than the 50/60 cycle power frequency), and calculates the instantaneous power for each sample. Those are added up (the time between samples is known) to get the energy numbers.
Old style meters were just a spinning disk and a set of counters. Time was utterly irrelevant to the issue, except that they sort of tried to schedule the meter readings about a month apart.
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 40 ·
