Electrical energy converted to heat in coil
The discussion revolves around a coil with multiple turns, resistance, and an induced current, focusing on the energy converted to heat in the coil due to electrical energy. The problem involves analyzing a circuit with a capacitor and a straight wire generating a magnetic field, leading to questions about the induced current and energy dissipation.
  • Participants explore the relationship between current, resistance, and energy dissipation, questioning the formulation of the problem and the assumptions made regarding the circuit components and their behaviors.
Participants are actively discussing the implications of the equations provided, with some suggesting that the problem may involve trick questions or misinterpretations. There is an ongoing examination of the integration of power to find total energy, and some participants have offered clarifications regarding the nature of power versus energy.
There are indications of confusion regarding the integration limits and the nature of the exponential terms in the equations. Participants are also considering the implications of ideal versus real inductors in the context of energy conversion.
Erik P
Given a coil with N turns, a radius of r, a resistance of R', and an induced current i'(t) running through the coil, determine the totale energy converted to heat in the coil for t>=0.EDIT:
The circuit on figure 4 consists of a resistance R and a capacitor with capacitance C. The voltage over the capacitor is V0 for the time t=<0 with the shown polarity. A small coil with N turns and a radius r is placed in the same plan as the large circuit, at a distance d from the wire ab. The coils resistance is R'. At the time t = 0 the switch is turned on. Both circuits are stationary and we assume that ONLY the straight wire ab, which is closest to the coil, generates a magnetic field. We can ignore the self-inductance from both circuits.
a.) Determine the current i(t) through the large circuit at the time t>=0.
\begin{equation}
i(t) = \frac{V_0}{R}e^{-\frac{t}{RC}}
\end{equation}
The wire ab is considered infinitly long and the magnetic field at the coil is assumed to be uniform (d>> r).
b.) Determine the direction and size of the induced current i'(t) in the coil for the time t>= 0.
\begin{equation}
i'(t) = \frac{r^2N\mu_0V_0}{2dR^2CR'}e^{-\frac{t}{RC}}
\end{equation}
c.) Calculate the total energy converted to heat in the coil for t>=0.
this is where the problem arises. The answer should be:
\begin{equation}
U = \frac{\mu_0^2N^2V_0^2r^4}{8R'R^3d^2C}
\end{equation}
I found the following, but it is for energy stored in a toroidal solenoid so I don't think it is correct:
\begin{equation}
U = \frac{1}{2}Li'(t)^2 = \frac{1}{2}\frac{\mu_0N^2A}{2\pi r}i'(t)^2
\end{equation}
Using the above equation:
\begin{equation}
U = \frac{\mu_0N^2r}{4}i'(t)^2
\end{equation}
But according to the answer this isn't correct.
Any formula for energy will have to involve time because the longer the duration that current flows, the more energy will be dissipated.
Is there a possibility it may be a trick question? You have a current i'(t) flowing in a resistance R'.
Well actually that formulation is my fault. This is the last problem of a 3 part problem, in the first two parts I found the current i'(t) that would be induced in a coil with a resistance of R', the last part simply asks what the total energy to heat conversion would be in the coil as a function of time.
If current is i'(t), what exactly is capital I?
Sorry, I should have been written as i'(t), will fix it.
Perhaps remember that an ideal inductor is lossless. So no energy is converted to heat in the ideal part of a real inductor. What about losses in the other parts of a real inductor?
Hmm... I think my explanation is causing more confusion than anything. Give me a few minutes to write the full original text in.
I updated the question so all the details are there.
Your equation 4 is for the energy stored in an inductor. Not the energy dissipated in the inductor.
Consider a resistor R with current I(t) flowing through it. What is the simple equation for the instantaneous power dissipated in the resistor.
Hey, thanks for replying. Was away when you sent that. The instantaneous power dissipated in the resistor is the product of the square of the current and the resistance over which the current runs?
\begin{equation}
P = I^2R \Rightarrow P' = i'(t)^2R'
\end{equation}
However this doesn't give the same result as the answer, this gives:
\begin{equation}
P' = \frac{r^4N^2\mu_0^2V_0^2}{4d^2R^4C^2R'}e^{\frac{t^2}{R^2C^2}}
\end{equation}
\begin{equation}
\end{equation}
Power is not the same as total energy. Power is the instantaneous energy dissipation with respect to time. How might you find the total energy from the power?
Intergrating over the power from 0 to t, at which point I get the same equation :) well sort of :( The problem is the integration of e^(x^(2)), I looked it up and it seems to involve 1/2 sqrt(pi) erf which isn't something I recall having had about in calculus. The answer sheet gives the equation without the sqrt(pi) erf part but otherwise seems to be the same as you can see from the OP. Am I making a mistake here?
I think you'll find that the exponent of e in your equations should be negative. Also, note that ##(e^{-x})^2 \ne e^{(-x)^2}##. So you'll want to check the exponent of e in your power equation for two reasons.
I ran it through wolfram alpha to check, and surely you were right about the exponent. I am however a little confused now because I get the following, keep in mind the i had to change the name of some things, like R' is now R_0, V_0 is now v etc.
as you can see I now have a negative value and e is still present, which it shouldn't be.
You've taken an indefinite integral, so you've ended up with an unknown constant. What are the integration limits for the time interval of interest?
I see the problem :D its from 0 to infinity, not 0 to t. Also the t isn't multiplied on the fraction, its only present as an exponent, so t=0 doesn't make the entire thing 0 it just makes the e part equal to 1 and for t = infinity we get e expression becomes 0, which means we have 0 - (above expression without the e part), so double negatives cancel out. Sorry, I guess I'm just tired... Should have caught that mistake.
  • · Replies 30 ·
11K
