Electromagnet coil core to yoke ratio?
The discussion focuses on optimizing the efficiency of electromagnet coils by determining the ideal ratio of coil core mass to yoke mass. It specifies that the yoke's cross-section should be at least twice that of the 5/16" diameter soft iron core. The use of 24 AWG magnet wire, rated for 0.6 amps, is highlighted, with a maximum power output of 2 watts per coil. To achieve approximately 1 Tesla in the air gap, around 40,000 amp-turns per coil are required, while only 30 amp-turns are necessary when the magnet is closed with another yoke.
  • Understanding of electromagnet design principles
  • Knowledge of wire gauge specifications, specifically 24 AWG
  • Familiarity with electrical resistance calculations
  • Basic concepts of magnetic field strength and amp-turns
  • Calculate I-squared R losses for 24 AWG wire at 6V DC
  • Research methods to measure magnetic field strength in Tesla
  • Explore different yoke materials and their impact on efficiency
  • Learn about optimizing coil winding techniques for better performance
Electromagnetic engineers, hobbyists building electromagnets, and anyone involved in optimizing magnetic field applications.
britishink
I'm building pairs of coils with standard core heights and diameters and linking each pair with a yoke. The magnets all run at 6V DC with windings of 24 AWG magnet wire in 6/8/10 layers.
Is there a ratio of coil core mass to yoke mass for maximum efficiency? (shown below)
The cross section of the yoke should be roughly at least twice the cross section of the 5/16" diameter soft iron core. More iron is not needed.
The current rating of the 24 AWG wire is about 0.6 amps. The average power in each coil should not exceed about 2 watts (it should not be too hot to touch). The wire resistance is about 26 ohms per 1000 feet. So calculate the length of the wire and the I-squared R losses. Calculate also the max current with 6 volts dc.
If you plan to use the magnet as pictured, you will need about ~40,000 amp-turns per coil to get ~1 Tesla in the air gap. If you plan the close the magnet with another yoke on the top, then you will need about ~30 amp-turns per coil to get ~1 Tesla inside the iron (no gap).
Bob S
  • · Replies 43 ·
  • · Replies 42 ·
  • · Replies 17 ·
  • · Replies 22 ·
  • · Replies 27 ·
11K
