Electromagnetic Waves and Induction
The discussion centers on calculating magnetic flux through a loop in relation to a solenoid. The magnetic field inside the solenoid is given as 0.20 T, and the loop has a diameter of 6.0 cm. The magnetic flux when the loop is perpendicular to the solenoid is calculated as 6.28×10-5 Wb. When tilted at a 60-degree angle, the flux calculation involves using the equation Φ = BA cos(θ), leading to confusion regarding the correct application of the cosine function and the area calculation.
  • Understanding of magnetic flux and its calculation
  • Familiarity with the equation Φ = BA cos(θ)
  • Knowledge of solenoids and magnetic fields
  • Basic geometry for calculating the area of a circle
  • Study the principles of electromagnetic induction
  • Learn about the application of the right-hand rule in magnetic fields
  • Explore the effects of angle on magnetic flux calculations
  • Review examples of magnetic flux in different orientations
Students studying electromagnetism, physics educators, and anyone seeking to understand magnetic flux calculations in relation to solenoids and loops.
jlmessick88
The 2.0-cm-diameter solenoid in the figure passes through the center of a 6.0-cm-diameter loop. The magnetic field inside the solenoid is 0.20 T.
What is the magnetic flux through the loop when it is perpendicular to the solenoid?
Φ1 = Wb
What is the magnetic flux through the loop when it is tilted at a 60 angle?
Φ2 = Wb
http://i63.photobucket.com/albums/h148/jlmessick88/jfk_Figure_25_P08.jpg
Φ = AB cos()
? No idea :(
Thanks
You have the equation for calculating Φ. You have B. You have A. You have θ. What seems to be the trouble?
getting confused with what i should be doing with the solenoid and the loop...wouldn't one effect the other or am i supposed to be using both diameters
The question asks what the magnetic flux through the loop is. The loop does not have a magnetic field, so how could it affect the solenoid?
oh! ok that makes sense...
but for when it's tilted 60 degrees... it would be .01^2 * pi = 3.14*10^-4 *.2T = 6.28*10^-5 * cos(60) = 3.14 * 10^-5...but that's not the correct answer...i don't understand why...
EDIT:
Express your answer using two significant figures.
=6.3×10−5
Correct
3.14*10^-4 *.2 = 6.28*10^-5
6.28*10^-5 * cos(0) = 6.28*10^-5
so for the second part wouldn't i just use cos(60)??
=6.3×10−5
Correct
Yes, you just use flux=BAcos(60). I don't know why you're doing:
but when i used BAcos(60), i get 3.14*10^-5, that's wrong...why??
Not really seeing why the answer is wrong. What does your book say?
i don't know what the answer is...it's just saying it's wrong...
Its the same answer for both.. even though I'm sure this is too late now
