Electromagnetism problem using Gauss's Law
This discussion centers on calculating the electric field around an infinitely long insulating cylinder using Gauss's Law. The charge density is given as ρ = 3r² (nC/m³). The solution involves constructing a cylindrical Gaussian surface and applying the formula \oint \vec{E} \cdot d\vec{A} = \frac{\sum Q_{en}}{\epsilon_0} to derive the electric field both inside and outside the cylinder. The final expressions for the electric field are E = 3rR²/2ε₀ for r > R and E = 3r³/2ε₀ for r < R.
  • Understanding of Gauss's Law and its application in electrostatics
  • Familiarity with electric field concepts and calculations
  • Knowledge of charge density and its implications in electric field calculations
  • Ability to perform surface integrals in cylindrical coordinates
  • Study the derivation of electric fields using Gauss's Law for different geometries, such as spheres and planes
  • Learn about the relationship between electric field and voltage, specifically the formula E = -∇V
  • Explore the application of Gauss's Law in real-world scenarios, such as calculating fields around power lines
  • Investigate the concept of linear charge density and its effect on electric fields for long wires
Students of electromagnetism, physics educators, and professionals in electrical engineering who are looking to deepen their understanding of electric fields and Gauss's Law applications.
hagisucks
Using Gauss's law calculate the electric field everywhere for the infinitely long insulating cylinder of radius R and charge density of rho = 3r^2(nc/m^3). SHOW ALL YOUR WORK INCLUDING DIAGRAMS.
I am lost.
I don't know where to start
Well...what is Gauss's Law? Write out. You should have had that in your "relevant eqtn"!
Electric Flux = qin/Eo
In integral form...?
I'm not sure what you mean.
Have you seen this before?
I pretty much drilled this equation into the back of my head...
No. I'll take it the surface integral of E dot dA is equal to flux. I can remember that. I am still confused about how to use that equation to solve this problem.
Well, the cylinder is infinitely long. What is the E-field emitting? what happens if the cylinder is a wire?
Is it emitting charge? I don't know, what happens?
You have a long wire (forget being cylinder for now), what is the E-field? What is the direction?
If it helps, draw a Gaussian Surface over the wire/cylinder.
I have absolutely no idea.
Do you know what Gauss's Law means...? What it states? Don't just direct meback to the formula. What is "dA"?
This was obviously posted a while ago, answering may help others though so:
Begin by constructing a cylindrical Gaussian surface of radius r and length l around the cylinder. Then the electric field outside of the cylinder is, by Gauss's law:
\ointE.da = Q / ε0 where Q is the total ENCLOSED charge.
The da on the left hand side refers to the area that the electric field passes through the Gaussian surface, not of the cylinder itself:
E x 2∏rl = Q/ε0
Now, the Q enclosed is the volume charge density multiplied by the volume in which Q is contained (i.e. the volume of the cylinder):
Q = ρ x ∏R^2 x l (R - the radius of the CYLINDER not the Gaussian surface is used)
Substitute back in:
E x 2∏rl = ρ x ∏ R^2 x l / ε0
E = ρ x R^2 / 2rε0
Then substitute ρ = 3r^2:
E = 3rR^2/2ε0 (outside; r>R)
For inside the enclosed charge has "the same r":
E x 2∏rl = ρl∏r^2 / ε0
E = ρr / 2ε0
Substitute ρ:
E = 3r^3 / 2ε0 (inside; for r < R)
E x 2∏rl = Q/ε0
Substitute back in:
E = ρ x R^2 / 2rε0
E = ρr / 2ε0
Substitute ρ:
May I join the discussion?
Will this line of reasoning apply to calculating (estimating) the electromagnetic field (in Gauss) that one would expect to measure at a given distance from a high voltage power line? Since I would not have the charge available, but may have the voltage and line current, could the field be calculated in Gauss (or Teslas and then multiply by 10^4)? Will you show me the formula?
Hello Steve, welcome to PF!
It would be better if you start a new discussion, do you see the date of the last post? :smile:
Yes, the exact same method can be applied. A typical "text-book example" gives an infinitely long wire with a linear charge density λ. Just as with a cylinder a cylindrical Gaussian surface can be used for a wire (a wire in reality is really just a thin cylinder so this makes sense).
For your question however if you have a scalar potential (voltage, V) there is a simple formula connecting this to the E field:
E= -∇V - δA/δt , where A is the vector potential
If ∇xE = 0 (i.e. B field not changing with time) then this reduces to:
E= -∇V
Which in the one dimensional case of a wire can be treated as:
E= -dV/dx
  • · Replies 26 ·
