rtareen
- Messages
- 162
- Reaction score
- 32
I have attached a small excerpt from my digital book where they start talking about emf. I am very confused. Let me explain what is confusing to me so that you can clear up what's bothering me.
They start of by saying that an emf device pumps charges by maintaining a potential difference called 𝓔. This potential difference exists between its terminals. So do the electrons move from the negative terminal, go around the circuit due to the potential difference, and then re-enter the battery through the positive terminal? So the battery does work to move it around the circuit? In the previous chapter about resistors we just assumed a potential difference between two points on a resistor. But apparently the potential difference across a resistor and 𝓔 are different quantities.
In the next section they take the charge carriers to be positive. I think they say that 𝓔 is the work the battery does within itself to take the positive charges from the low potential (where it enters) to the high potential (where it leaves so it can go around the circuit). So does this mean the same 𝓔 has two functions? It does work q𝓔 to push the charges around the circuit and the same amount of work q𝓔 to put them back in a position to follow the potential difference it sets up. Please let me know if this is right, or if not, please explain in a way I can understand.
Now let's just focus on what goes on outside of the battery and try to understand Figure 27-1. The battery sets up a potential difference between its terminals so that the positive charge goes around the circuit. Now we can see that there is a resistor halfway between the positive and negative terminals. We know that V = RI. So the voltage difference of this resistor would not be the same as 𝓔 but rather it would be its own resistance times the current that was set up by 𝓔? And is the resistance zero everywhere else besides the resistor? Is that right? If not, please explain in an understandable way. Also, we know that energy is dissipated by a resistor at the rate of ##P = \frac{V^2}{R}##. So the charges have less energy going out of the resistor then they did coming in. What energy is this? If the flow is steady then it cannot be Kinetic. Is it electric potential energy? Do the charges have less potential energy because it went from the higher potential to lower potential within the resistor (which has its own potential difference)? Please let me know what's going on.
Now let's look at the more complicated, Figure 27-2. So the positive current moves from the high potential of the positive side of B to the less high potential that is the positive side of A. Is that right? So it is moving basically because of a potential difference given by ##V_{B+} - V_{A+}## ? Next, what happens as it goes through battery A? It says that the chemical energy within batter A is increasing such that battery B is charging battery A? Let me ask you one question. Does the charge simply flow from the high potential (positive side of A) to the low potential (negative side of A) as if nothing else is going on inside the battery? How does this relate to the increasing chemical energy? Next, once the charge gets out of A, what potential is there to keep the charges moving. Does the negative side of A have to have more potential than the negative side of B? Thats the only way I can see the charges still moving in this part of the circuit. And what about the motor and resistor? They say energy is lost to the motor and the resistor. But the potential differences remain the same? So what energy is lost?
