Electron and proton between two plates
5 replies · 2K views
cseil
Between two plates (distant 4cm) there's an electric field (E = 100N/C).
A proton starts moving from the positive plate and an electron starts moving from the negative plate.
At what distance from the positive plate do they meet? (is "meet the right verb here? :biggrin:)
## a = qE/m ##
## v = at ##
## U = - \frac{e^2}{4\pi\epsilon_0 r}##
## U_i + K_i = U_f + K_f ##
I calculated ##U_i##.
It is ##-5.76x10^{-27} J ##.
Now,
## U_i = Kf ##
and
## Kf = \frac{1}{2} m_p v_p^2 - \frac{1}{2}m_e v_e^2##
I replace ## v = at = \frac{eEt}{m} ##
## U_i = [\frac{1}{2} e^2E^2 ( \frac{1}{m_p} - \frac{1}{m_e})] t^2 ##
## t = 6.39x10^-12 s ##
## x(t) = \frac{1}{2} at^2 ##
I obtain a very small value of x. 10^-13 or so.
There's a big difference (4 orders of magnitude) between the acceleration of the electron, that's true.
But they meet at very very very small distance from the positive plate.
Could you tell me if this is right?
Thank you so much
10^-13 in what units?
No, it is not right.
Think: Forces of the same magnitude act on both particles, F=qE. And you correctly wrote that the acceleration is a=qE/m.
me=9,11x10-31kg. mp=1.67x10-27kg.
The ratio of the masses mp/me=1833. What is the ratio of the accelerations?
Again you wrote correctly, that the distance traveled by one particle is x=a/2 t2. They travel for the same time. So what is the ratio of the distances they travelled?
Sorry, I forgot to say the units. 10^-13 m!
The ratio of accelerations is ##\frac{a_p}{a_e} = \frac{1}{1833} ##
The ratio of distance is the same, because t is the same.
I don't understand how to use it, though
Oh, ok
## 0.04 = x(1833+1) ##
x is ##2.18x10^{-5}##m.
What was my mistake then?
