Electron and proton penetration
The discussion centers on the penetration capabilities of electrons and protons into matter, specifically under two conditions: equal energy and equal speed. When both particles possess the same energy, electrons penetrate further due to lower collision losses as described by the Bethe-Bloch formula. Conversely, when both have the same speed, protons, having significantly higher mass and energy, penetrate deeper despite similar energy loss per length. The importance of Bremsstrahlung radiation is noted, particularly at higher energies, but is minimal at a few MeV.
  • Understanding of the Bethe-Bloch formula
  • Knowledge of particle physics, specifically electron and proton properties
  • Familiarity with concepts of stopping power and energy loss in matter
  • Basic grasp of relativistic physics, including the concept of gamma (γ) factor
  • Study the Bethe-Bloch formula in detail to understand energy loss mechanisms
  • Research Bremsstrahlung radiation and its effects on electron penetration
  • Explore the mass-energy equivalence principle, particularly E=γmc²
  • Investigate the differences in stopping power between various particles at different energy levels
Students and professionals in physics, particularly those focusing on particle physics, radiation physics, and materials science, will benefit from this discussion.
adamworth
Which, of an electron and a proton (of a few Mev), is more likely to penetrate further into matter if they both have:
a) The same energy
b) The same speed
Total stopping power = collision loss + radiation loss
(de/dx)t = (de/dx)c + (de/dx)r
a) Electron will penetrate further. If both have the same energy, collision loss is less for electrons as (de/dx)c = 1/v2
b) Both will penetrate the same distance. If both have the same speed, collision loss is the same for both electrons and protons. Radiation loss is minimal as this only comes into effect for higher energies (many Mev).
Bremsstrahlung could be important for electrons.
"The same speed" doesn't allow both electrons and protons to have a few MeV, it is unclear which particle is supposed to have an energy in this range.
I've attached the question below. I think it means electrons of a few MeV. My reasoning is that Bremsstrahlung doesn't have much of an effect at a few MeV, so both the electron and proton will penetrate the same distance. But I'm not sure...
At the same speed, you have to compare electrons at a few MeV with protons at a few GeV. It should be clear what travels faster, even if you neglect Bremsstrahlung.
So you believe the proton will penetrate deeper? How do I explain this in terms of the Bethe-Bloch formula?
The proton will penetrate much deeper. Its energy loss per length will be similar but it has much more energy.
Ok thanks for the help. Is there any particular resource where you can compare electron and proton energies for a given speed?
##E=\gamma m c^2##, a given speed means a given ##\gamma## and you should know the approximate proton to electron mass ratio.
  • · Replies 54 ·
11K
  • · Replies 44 ·
