Electron in a magnetic field statements
3 replies · 3K views
Saitama
A beam of electrons moving with a momentum p enters a uniform magnetic field of flux density B perpendicular to its motion. Which of the following statement(s) is (are) true?
A)Energy gained is ##p^2/2m##
B)Centripetal force on the electron is ##Bem/p##
C)Radius of the electron's path is ##p/(Be)##
D)Work done on the electrons by the magnetic field is zero.
The force due to magnetic field on an electron is always perpendicular to the motion and hence does no work on it. So D) is correct. Since no work is done, no energy is gained and A) is eliminated.
[tex]\because \frac{mv^2}{r}=evB \Rightarrow r=\frac{mv}{eB}=\frac{p}{eB}[/tex]
where r is the radius of electron's path and hence C) is correct. From the above equation, mv^2/r represents the centripetal force. It is equal to eBp/m and B) also eliminates. Therefore, the statements which are true are C) and D) but the answer key states that it is C). :confused:
I agree with you ! I would say C and D are correct
Thanks technician for the check. :)
Yup, it is C and D. Work done = evB.dScosθ
θ here, = 90. Hence it IS C and D.
