Electron moving in magnetic field. (Physics 2, non calc)
The discussion centers on the motion of electrons in Earth's magnetic field, specifically addressing their trajectory when fired eastward. The electrons experience a circular motion due to the perpendicular magnetic force acting as centripetal force. The magnitude of Earth's magnetic field is calculated to be 2.38 x 10^-5 T based on the time of 1.5 x 10^-6 seconds for the electrons to return to their initial position. To achieve a straight-line path, the electrons must be fired at an angle determined using trigonometric functions, considering the horizontal component of the magnetic field is 1.9 x 10^-5 T.
  • Understanding of Lorentz force and its application in charged particle motion.
  • Familiarity with the concepts of centripetal force and circular motion.
  • Knowledge of magnetic field strength and its components.
  • Basic proficiency in trigonometry, specifically SOHCAHTOA for angle calculations.
  • Study the principles of charged particle motion in magnetic fields using the Lorentz force equation.
  • Learn about the effects of Earth's magnetic field on charged particles, including variations in different locations.
  • Explore the concept of helical motion of charged particles in magnetic fields.
  • Practice calculating angles using trigonometric functions in the context of magnetic fields.
Students studying electromagnetism, physics educators, and anyone interested in the behavior of charged particles in magnetic fields.
pdeco1
Electrons are fired Eastward at a certain location near Earth's surface. Ignore gravity.
A. Describe the motion of the electrons and describe the trajectory they follow.
B. If the electrons first return to their initial positions after 1.5 x 10^-6 seconds, determine the magnitude of the Earth's magnetic field.
C. If it is known that the horizontal component of the magnetic field is 1.9x10^-5 T. In precisely which direction should the electrons be fired so as to travel in a straight line? You may express any angle as an inverse trigonometric function.
r=mv/qB
A. The perpendicular magnetic force acts as centripetal force which keeps the particle in rotation around the Earth changing its direction but not velocity.
B. t= 1.5x10^-6 s, t = (2)(pi)(m)/qB, Solving for B = 2.38x10^-5 T
C.The "horizontal component" is tripping me up. Is there two magnetic fields here? One from the Earth and one from the moving electron?
hi pdeco1! :smile:
so the shape of the motion is … ? :smile:
no, the Earth's magnetic field is at an angle to the horizontal, different in different places on the Earth …
see http://en.wikipedia.org/wiki/Magnetic_dip" for details :wink:
A. The path is circular.
Can you offer more advice on part C. My diagram has electron heading east, with the force downwards and the magnetic field rotating in and out of the page, which makes it horizontal to the earth.
While the electron is perpendicular to the Earth it with experience a centripetal force, the force is greatest at 90, and decreases as the angle between the path and the magnetic field decreases. Does the electron need to be fired vertically at 90 degrees to travel in a straight line?
hi pdeco1! :smile:
yup! :biggrin: (or helical :wink:)
the only path that isn't helical is a path parallel to the field :wink:
I understand the theory, but I am not sure how to figure out the angles. Any help would be appreciated.
Thanks.
The key to the problem was understanding that "horizontal" meant a uniform north field.
Set up the magnetic field values along an xy plane and use SOHCAHTOA to find the angle. The north(horizontal) value is given, combined with the magnetic field calculated from part B and the problem is easily solved.
  • · Replies 25 ·
