Electron scattering: nuclear radius to nucleon number relationship
The discussion focuses on the relationship between the root mean square (rms) radius and the nuclear radius R in the context of electron scattering. The gradient of the graph plotting against A^{1/3} is given as 0.96, leading to the equation R=R_{0}A^{1/3}. The rms radius for a uniform sphere is derived using spherical coordinate integrals, resulting in the formula = (3/5)R^{2}. This confirms that the expectation value of r^{2} is effectively being calculated.
  • Understanding of root mean square (rms) radius in physics
  • Familiarity with the concept of nucleon number (A)
  • Knowledge of spherical coordinate integrals
  • Basic grasp of nuclear physics and electron scattering
  • Explore the derivation of the rms radius for different geometries
  • Study the implications of the charge radius in nuclear physics
  • Learn about the significance of the gradient in nuclear radius relationships
  • Investigate the role of electron scattering in determining nuclear properties
Students and researchers in nuclear physics, particularly those studying electron scattering and the properties of atomic nuclei.
AlexCdeP
Hi! I am extremely confused on what seems to be quite a simple question. The question contains a graph of root mean square radius <r^{2}> plotted against A^{1/3} where A is the nucleon number. In the lecture notes he specifies that <r^{2}> is not the same as R but does not really say specifically what the difference is. It is given that the gradient of the line in this graph is 0.96. I am meant to find the value of R_{0} in the relationship R=R_{0}A^{1/3} but I'm not certain how to find it because I don't know what the relationship between the rms r and R is.
Any help would be amazing.
I have worked through trying to use the charge radius but without success, he never mentioned the charge radius in the lecture so I'm not sure what to do. http://en.wikipedia.org/wiki/Charge_radius
If you have a uniform sphere of radius R, what is the (squared) rms radius <r2> of its volume? Hint: You'll need an integral (or a formula).
Thanks so much I think I'm on the right track now. So for a uniform sphere you use some spherical coordinate integrals to find that the rms radius is related to the radius by \frac{3}{5}R^{2}. Is this the correct formula to get?
Also am I right in saying that I am effectively finding the expectation value of r^{2}?
Finally got the answer! Thanks again man couldn't have done it without you!
Yup.
  • · Replies 29 ·
  • · Replies 21 ·
