Electronics cabinet cooling system
The discussion focuses on optimizing the airflow and cooling system for an electronics cabinet using two axial fans with louvers. Key factors include the geometry of the louvers, specifically the angle of opening and size, which significantly affect airflow and temperature control. Participants emphasize the importance of understanding pressure drop and turbulence in airflow design. For practical solutions, it is recommended to refer to manufacturer catalogs that provide tested configurations for heat load management.
  • Understanding of axial fan operation and specifications
  • Knowledge of louver design and its impact on airflow
  • Familiarity with airflow concepts such as pressure drop and turbulence
  • Experience with thermal management in electronic systems
  • Research the impact of louver angle on airflow efficiency
  • Explore different axial fan specifications and their cooling capabilities
  • Study the relationship between turbulence and cooling performance in confined spaces
  • Review manufacturer catalogs for optimal cabinet configurations and heat load ratings
Electronics engineers, HVAC designers, and anyone involved in thermal management of electronic systems will benefit from this discussion.
dhaval trivedi
Hello
I am designing the cooling system for cabinet with all the electronic components inside.
I am using 2 axial fan with louvers at one end and other end has exhaust louvers.
Currently i want to optimize the air flow/cfm inside the cabinet so that i can maintain overall temperature under control.
can you help me to understand what is the problem case i should consider.
I want to understand the effect of louver geometry on air flow system design.
Angle of opening
size of louver
Terms like
pressure drop
turbulence
what is good what is not !
Welcome to the forum.
This is one of those questions that designers face many times. You should be able to look up the answer in catalogs of cabinets from manufacturers. They will tell you things like the heat load supported by various configurations of cabinet, louver, and fan. Doing it from first principles is a long, complicated task. Unless you are most interested in the task for learning purposes, I would say to dispense with doing it yourself. Depend on prior experience of people who make cabinets and have been testing them for many years.
  • · Replies 22 ·
  • · Replies 21 ·
  • · Replies 16 ·
