Electronics: trying to understand grounding point
This discussion centers on understanding grounding points in electrical circuits, specifically the concept of potential differences. The user grapples with calculating voltage drops and the implications of setting a reference point to zero. Key insights include the clarification that while potential differences can be set to zero, individual points cannot; the total potential difference remains constant regardless of the chosen ground point. The conversation emphasizes the importance of understanding voltage direction in relation to current flow.
  • Basic knowledge of electrical circuits
  • Understanding of potential difference and voltage
  • Familiarity with Kirchhoff's Voltage Law (KVL)
  • Ability to interpret circuit diagrams
  • Study Kirchhoff's Voltage Law (KVL) in detail
  • Learn about voltage drop calculations in series and parallel circuits
  • Explore the concept of reference points in electrical engineering
  • Investigate the relationship between current flow and voltage in circuits
Electronics students, electrical engineers, and anyone interested in mastering circuit analysis and voltage concepts.
Femme_physics
Sorry for jumping through topics, I just have an electronics test tomorrow and I want to see I fully understand grounding points.
So I made up this circuit and found its voltage drop at every point
http://img137.imageshack.us/img137/3352/volts1.jpg
Now if I set Vab = 0 (i.e. turn Vab to the grounding point), I'm trying to calculate the potential differences now, but my total potential difference between -10 and +10 is only 20v. I'm missing 10V somewhere!
http://img845.imageshack.us/img845/1601/volts2.jpg
Grrrrrr
Does point mean sector? Vab is the potential difference between points a and b.
ehild
So you can't set a point = 0, only potential difference = 0?
No, you can only set a point to 0, not a potential difference. Vab is a potential difference, so you don't get to choose its value; the Universe chooses it. You can, however, choose the potential at either "a" or "b" to be whatever you want.
Maybe an analogy would help. The height difference (analogous to potential difference) between the top and bottom of Mount Everest is a set value. It is what it is; nature has decided its value, and you can't change it. However, you can arbitrarily define the bottom of Mount Everest to be at height=0, or height=-1000 m; the top of the mountain would then be at 8000 or 7000 m (assuming the mountain is 8000 m tall).
Good example.
And yes setting Vab to zero would be OK, only when the current between a and b is zero.
So no matter where I set my ground point, the potential difference between 2 points remains constant?
Femme_physics said:
I presume that the answer to my question above this post is "yes", in this case setting b = 0 I should be all correct here:
Correct?
PS calculator watches ftw!
Yes, the answer to your post above is yes. :)
And yes, Va = 10.
However, Vc = -20.
Voltage still goes down in the direction of the current.
Or perhaps I should say, that current flows down the mountain of voltage, like a mountain stream. ;)
That clears up a lot, thanks! :)
And yes, Va = 10.
However, Vc = -20.
I see, so I should've done
Vbc = Vb - Vc
And not
Vbc = Vc - Va
It's always the first minus the second, yes?
Vbc = Vb - Vc
And not
Vbc = Vc - Va
I guess so, but that would be mostly about how you define it yourself.
However you define or use it, make sure that voltage goes down in the direction of your current.
Makes perfect sense :) And, as it hit the source, it increases again, right?
Yep. Guaranteeing that KVL works! :)
Need...consume...more...science...knowledge.. *drools*
Thanks :wink:
Don't forget the item that increases your abilities! :devil:
  • · Replies 38 ·
17K
  • · Replies 19 ·
