Calculating Magnetic Flux Density for an Electron Orbiting Near Earth's Surface
The discussion centers on calculating the magnetic flux density (B) of Earth for an electron orbiting near its surface, concluding with a value of 8.9e-12 Tesla. The participants clarify that the gravitational force on the electron is negligible compared to the magnetic force, which equates to the centripetal force. A participant expresses confusion regarding the calculation of the electron's velocity using the equation v=(Bqr/2m) ± 0.5√((Bqr/m)²+(4Gm/r)), ultimately yielding an unreasonably high value of v=2.37e13. This indicates a potential error in the application of the formula or the values used.
  • Understanding of magnetic flux density and its units (Tesla)
  • Familiarity with the Lorentz force and centripetal force concepts
  • Basic knowledge of gravitational force calculations
  • Proficiency in algebraic manipulation of equations
  • Review the derivation of the Lorentz force equation
  • Investigate the implications of gravitational force on subatomic particles
  • Learn about the properties of magnetic fields near Earth's surface
  • Examine the effects of electron velocity on magnetic interactions
Physics students, educators, and researchers interested in electromagnetism, particularly those exploring the behavior of charged particles in magnetic fields.
Ben King
I've been given a question to find the magnetic flux density of the Earth if an electron is orbiting near to the surface. The answer to the question makes the magnetic force equal to the centripetal force and solves for B from there.
However, I am confused to why the gravitational force has no effect and won't the direction of rotation of the electrons have an effect on the direction of the magnetic force and hence the magnitude of the centripetal force? Thanks
The answer given was 8.9e-12 Tesla
Welcome to the PF.
(In the future, please use the Template that you are provided when starting a new schoolwork thread -- it helps to organize your post).
I'd start by comparing the Lorentz force to the gravitational force on the electron. Maybe the gravitational force is negligible...? Can you show us the calculations?
Thanks for the reply. Your suggestion about the gravitational force being negligible is true I think, so that answered that question. However I altered the equation to find velocity of the electron if the magnetic field strength was the same as the surface magnetic field strength of the Earth and got an answer that was way too large, I'll show the equation below. Is there an error in my maths?
##v=(Bqr/2m) \pm 0.5*\sqrt{(Bqr/m)^2+(4Gm/r)} ##
from ##v^2-(Gm/r)-(Bqr/m)v=0##
I googled the mean value for magnetic field strength on the Earth's surface and found it to be ~##45e-6## Tesla, but when I used that number in the formula I got an answer of ##v=2.37e13##, which is obviously not correct. Thanks again
  • · Replies 31 ·
