Electrostatic charge of Scotch tape
  • Context: Undergrad
  • Thread starter Thread starter TVP45
    Charge Electrostatic
The discussion centers on the electrostatic charge properties of Scotch tape, specifically its ability to acquire a negative charge when separated from another piece of tape. Participants clarify that the plastic composition of the tape, along with the triboelectric series, indicates that the top piece becomes negatively charged upon separation. The interaction between the tape and surfaces, such as glass, enhances charge uniformity, while handling the tape can disrupt charge distribution. The conversation also highlights the differences between modern Scotch tape and older cellophane tape, with the latter consistently acquiring a negative charge.
  • Understanding of Coulomb's Law
  • Familiarity with the triboelectric series
  • Basic knowledge of electrostatics and charge distribution
  • Awareness of material properties, specifically plastics and adhesives
  • Research the triboelectric series and its implications for different materials
  • Explore experiments involving electrostatic charge and insulators
  • Investigate the differences in charge properties between modern Scotch tape and older cellophane tape
  • Learn about the effects of surface materials on electrostatic charge distribution
Students in physics, educators conducting experiments on electrostatics, and anyone interested in the practical applications of charge separation techniques.
TVP45
The other day I ran across a writeup for a general physics experiment (it might have come out of a high school AP course - I'm not sure) about using charged Scotch tape to separate charges for the purpose of measuring the charge through a torque equilibrium setup. The technique was to put a piece of tape, sticky side down, on a surface, put another piece, sticky side down, on top of the first, and then rip off the top piece and use it to make a crude electroscope.
So, I understand how this works (it requires a fair amount of hand-waving and beard-muttering to say this is a good example of Coulomb's Law, but whatever...) but I came up short as to why the writer thought it plainly obvious that the top piece would be negatively charged. I thought it might just be a slip till I found another similar writeup from a University I won't name stating pretty much the same thing.
What am I missing? What is there about Scotch tape that makes it so clear (notice I avoided any pun about transparent) that the top piece would be negative? Besides, I can't get one to be negative.
It's made of plastic and most plastics acquire a negative charge, when they do acquire a charge:
http://www.siliconfareast.com/tribo_series.htm
Be grateful: you got a cheerful roll.
But both the top and bottom pieces are plastic. I'm still puzzled. But your joke about the cheerful roll got me thinking. Would this be different with the older cellophane tape? I have no idea where to find that, but I'll give it a try. Thanks.
Two pieces of the same material can easily acquire different amounts of the same charge and regard each other as opposite in charge. As can two or more different parts of the same piece of material. They know the top piece will be negative simply because it's plastic. (That doesn't mean it will automatically be more negative than the bottom piece).
I am pretty sure the point of using tape is to insure the contact between the first piece and the surface you stick it to is as uniform as possible, and the same for the second piece and the first piece. That way, when you pull the second piece up the charge it acquired from contact with the first piece should be as evenly distributed over the length of the tape as it reasonably can be here.
The charge you give an insulator stays right where you put it: it doesn't spread out by itself the way it would on a conductor. One thing to consider is that your handling of the tape after you pull it up might be upsetting the uniformity of the charge distribution creating a situation where some parts of the tape are less negative than others resulting in an overall neutrality. You'll see from the list at the link that your hands tend to be positive and that touching the tape anywhere with your fingers is going to change the charge at the point of contact.
Since glass tends to acquire a positive charge it might enhance the result if you stick the first piece to a sheet of glass (got an old picture frame?). That will also optimize flatness, hence uniformity of contact.
No, actually you provided the clue in your first post. I found some old style cellophane tape (you remember, the kind that turns yellow, gets brittle, and then falls off). It does acquire a negative charge pretty consistently. It's the new, transparent tape that acquires a positive charge, usually small. Whoever wrote that lab procedure I read must have written it many years ago. Perhaps they never thought there would be magic tape? Thanks for the idea!
You must have two different materials to transfer charge. One is tape; one is glue.
Part of the mechanism for sandwich wraps to work is that when the plastic is pull away from the roll the static electricity, a negative charge, helps it to stick to the relatively positive containers etc.
If I pull a piece of magic tape off the roll, say 6 inches long, it seems already to be charged up and will cling to my hand. Either side. Both the sticky and smooth side are electrostatically attracted to my hand. I assume from the triboelectric series my hand is positive.
We might start with some basics. Given two uncharged insulators, the total charge adds up to zero after separation. The charge on one will increase as much as the other decrease. If one is charged positive, the other is charged negative.
One side of the magic tape is a layer of glue. The other side is plastic, so the two materials being separated are different at their interface.
The charge on the free end of the tape will be due to its glue side. Though the unbalanced charge remains on the glue side, the electric field surrounds the tape on both sides.
You haven't rubbed your hands on the tape to transfer charge, so where your hand stand in the triboelectric series doesn't matter. But your body is a conductor. As you move the tape
close to your hand it attacts the opposite charge in your body to your hand.
Thanks much, Phrak. I was discounting the glue and forgetting I can also function as a conductor
  • · Replies 36 ·
  • · Replies 18 ·
  • · Replies 16 ·
