Electrostatic collision between two masses
3 replies · 2K views
unscientific
I've done part (a) and (b) using conservation of momentum and energy..for part (c) I'm not sure how to find the minimum angle ∅. I have also worked out the velocities of m1 and m2 just before the collision as required in part (a).
I've done a sketch that shows something like:
I know that in the zero-momentum-frame the total momentum must be zero, so their momentum are aligned. (different masses results in them having different velocities, in order to ensure Ʃp = 0)
Just for the math folk, let's use ##\varphi## rather than the empty set for our variable. :-p
You have the velocities of the two masses. Velocity is a vector. The question you need to ask yourself is "how do you find the angle between two vectors?"
You probably meant speed, in which case...how do you relate speed and velocity?
I know the answers to all your questions, but I'm not sure if they're helpful in this question...:confused:
