Electrostatic Force Exerted Between Two Protons
The discussion focuses on calculating the position of a second proton such that the electrostatic force it exerts on a first proton balances the gravitational force acting on the first proton. The relevant equation is derived from Coulomb's law, F = (k×Abs[q1]×Abs[q2]) / r^2, where k = 8.99×10^9 Nm^2/C^2. The correct solution for the distance r, where the electrostatic force equals the weight of the proton, is found to be r = 0.118471 meters. The initial incorrect attempts were due to miscalculating the gravitational force and misunderstanding the equation setup.
  • Coulomb's Law for electrostatic force calculations
  • Gravitational force calculations near Earth's surface
  • Basic algebra and equation solving techniques
  • Understanding of fundamental particle properties, specifically protons
  • Learn how to apply Coulomb's Law in various electrostatic scenarios
  • Study gravitational force calculations in different environments
  • Explore the implications of electrostatic forces in particle physics
  • Investigate the relationship between electric and gravitational forces in physics
Students in physics, educators teaching electrostatics, and anyone interested in the interactions between charged particles and gravitational forces.
tjrana0
A proton is in a vacuum near the surface of Earth. Where should a second proton be placed so that the electrostatic force it exerts on the first proton balances the weight of the first proton?
You need to post your attempt.
The first attempt, I got 1.51911E-14 which was incorrect.
It says "Did you use the Coulomb equation to get the electrostatic force? Do you recall how to calculate the gravitational force on an object (the weight) near Earth's surface?"
I did do all of the above, but with no success.
proton = 1.602176 10^-19;
Solve[1 == (k proton^2)/r^2, r]
{{r -> -1.51911*10^-14}, {r -> 1.51911*10^-14}}
This was the answer that was incorrect.
I thought that the left side of the equation was 1, for some reason, I'm not sure. If it is 0, then the equation is unsolvable. What did I do wrong?
If it is near the surface of the Earth, then a gravitational force acts on it, its weight, mg.
You want the weight to be the same the electric force.
So you need to equate mg to the formula for the electrostatic force.
I did 1.6762622*10^-27*9.80665 == 8.99*10^9*1.602*10^-19*1.602*10^-19/r^2
and solved for r and got the right answer! Thank you!
Solve[1.6762622*10^-27*9.80665 ==
8.99*10^9*1.602*10^-19*1.602*10^-19/r^2, r]
{{r -> -0.118471}, {r -> 0.118471}}
r=0.118471m
