Yeah, the design I'm talking about is quite a lot more powerful than a wimshurst for the number of disks. Because disks are sandwiched between two inductors, you get ~4x the amount of charge per sector compared to a wimshurst machine. Womelsdorf machines are set up with a sandwiched disks, but they aren't the only one that use that technique, but if you refer to
https://www.coe.ufrj.br/~acmq/ptable.html you can see that it produces a significantly higher current for the number of rotors at the same rotor size compared to the wehrsen machine which uses a inductors on only one side of the disk rotor.
The womelsdorf doesn't necessary separated the output and inductor plate combs/brushes though. That was done to toepler machines later on as a means to stabilise the voltage and increase opperational efficiency.
You have double the inductance and, because the sectors on a wimshurst are the inductors for the sectors on the other rotor, you don't actually benefit from a current production perspective from the second disk unless you offset the output combs so that they aren't puling charge off of directly opposite sectors.
So the wimshurst looks cool, but if you're after practicality and high voltage power production, stationary inductors are the way to go.
Simplifies the drive train as well allowing you to mount the disks on the input shaft directly. The disks can be stacked like pancakes with inductors in between as well and each disk and inductor pair added to the stack proportionally increases current production.
But wimshurst machines are beautiful, mesmerizing and fairly useful machines too.
