Electrostatic potential inside/outside sphere
The discussion focuses on calculating the electrostatic potential V(r) both inside and outside a uniformly charged sphere of radius R with total charge Q. The electric field E is expressed as E = Qr/(4πε₀R³). To find the potential V, the relationship V = -∫E·dl is utilized, emphasizing the need to integrate the electric field correctly without a closed loop. The correct approach involves using the radial property of the electric field to derive the potential from its gradient.
  • Understanding of electrostatics and electric fields
  • Familiarity with the concept of electric potential
  • Knowledge of calculus, specifically integration techniques
  • Basic principles of spherical symmetry in physics
  • Study the derivation of electric fields from charge distributions using Gauss's Law
  • Learn about the relationship between electric field and potential in electrostatics
  • Explore integration techniques for vector fields in spherical coordinates
  • Investigate the behavior of electric potential in different geometrical configurations
Physics students, electrical engineers, and anyone studying electrostatics or working on problems involving electric fields and potentials.
j3dwards
A sphere of radius R carries an electric charge Q, uniformly distributed inside its volume.
(a) Using the expression for the electric field given in the lectures, compute the electrostatic potential V (r) inside and outside the sphere.
E[/B] = -V
E[/B] = Qr/4πεoR3 = -V
VE= - ∫c E . dl
But now I'm really unsure of how you get V from this? Because you can't divide by the gradient function... So do I integrate E = Qr/4πεoR3 to find V?
You also need the expression of the field outside the sphere.
j3dwards said:
VE= - ∫c E . dl
Correct, except for the "C" subscript after the integral, you will not be integrating in a closed loop, instead use the radial property of the field to find V from its gradient.
  • · Replies 22 ·
