Electrostatics charge density
The discussion focuses on calculating charge density as a function of radial distance (r) from an electrostatic field. The method of using the divergence of the electric field vector E is confirmed as correct for this calculation. The constant E0 is generally assumed to be constant unless specified otherwise, in which case its variation with spherical coordinates must be understood. The final answer cannot be simplified further based on the provided information.
  • Understanding of electrostatics and electric fields
  • Familiarity with vector calculus, specifically divergence
  • Knowledge of spherical coordinate systems
  • Basic principles of charge density in electrostatics
  • Study the concept of charge density in electrostatics
  • Learn about the divergence theorem in vector calculus
  • Explore the implications of varying constants in electrostatic equations
  • Review spherical coordinates and their applications in physics
Students studying electrostatics, physics educators, and anyone involved in solving problems related to electric fields and charge density calculations.
twotaileddemon
I didn't know how to display a lot of the symbols, so I wrote the problem out in microsoft word, took a screenshot, uploaded it to photobucket, and linked it.
Basically, I have to find the charge density as a function of r given the electrostatic field in the image. Any constants are positive. Bold means it's a vector; ignore the green underline; the del function is upside down - sorry about that.
http://img.photobucket.com/albums/v696/talimtails/aphysicswork.jpg
My questions are..
1: Is my work method correct? i.e. is this how you solve for charge density?
2. Is there a way to simplify it more?
3. Is E0 a constant or not? The problem doesn't really say and is ambiguous to me. If it's not, how should I approach it? Thanks.
In all cases... please don't tell me if my answer is right or wrong. YES/NO answers are very much appreciated.
Relevant equations I used in the image
My attempt is in the image. ^_^
First, is the vector \vec{r} in E meant to be the *unit* vector in the r-direction, or not?
Not the gradient, but the divergence. You cannot take the gradient of a vector field.
1. The approach is correct.
2. I don't think your final answer can be simplified, but I haven't checked your math.
3. I think you can assume that E0 is constant, no reason to expect it not to be. If it is not, you have to know how it varies with r, theta and phi.
Yes, r at the end in bold is the radial unit vector
I took the divergence of E and assumed spherical for the vector derivative
Thanks for your help!
  • · Replies 18 ·
