Elementary differential equations: transformations
4 replies · 2K views
Mdhiggenz
(x+2y+3)dx+(2x+4y-1)dy=0
a1= 1 b1=2 a2=2 b2=4
a2/a1=b2/b1
Therefore z=x+2y
Here is where I get confused I understand that they must get a dz in the equations thus they take the derivative with respect to y of the following equation z=x+2y
thus giving dz=dx+2 or dz-dx/2
What I don't understand is the simplification process that occurs now
(z+3)dx +(2z-1)(dz-dx/2)=0
then the book goes on to transform it into
7dx + (2z-1)dz=0
I have no idea what they did to get to that step.
a2/a1=b2/b1
Therefore z=x+2y
This isn't right. When you differentiate, you should get dz = dx + 2 dy. You can't have that lone 2 hanging around. It needs to be multiplied by dy. Then when you solve for dy, you get dy = (dz-dx)/2. Your second mistake was leaving out the parentheses.
Does it make sense after you make those corrections? It's just algebra from here.
7dx + (2z-1)dz=0
It does clear up a few things but I am actually stuck on the algebra portion.
What I am doing in that case is first multiplying both sides by 2 and I get
2zdx+6dx+(2z-1)(dz-dx)=0
2zdx+6dx+(2zdz-2zdx-dz+dx)=0
7dx+2zdz-dz=0
In my mind I want to make it 7dx+zdz=0
But the book factors out the dz to make it 7dx+(2z-1)dz=0
Why do they go that route?
To put it bluntly: because what you want to do in your mind is wrong. :smile:
When you combine the dz terms, what you are doing is factoring. You pull out the common factor of dz to get (2z-1) dz. You can't do anything to simplify the expression from here.
If you had, instead, 2z dz - z dz, you'd factor dz out to get (2z-z)dz. This time, you can simplify what's in the parentheses to end up with z dz. Or even better, you could pull out the common factor of z dz to get 2z dz - z dz = (2-1) z dz = z dz.
Awesome thanks man! (: I love it when math makes sense.
