EM Lagrangian in terms of E and B
  • Context: Graduate
  • Thread starter Thread starter Rocky Raccoon
    Em Lagrangian Terms
The discussion revolves around the use of electromagnetic potentials (phi and A) as independent degrees of freedom in the electromagnetic Lagrangian, contrasting this with the use of electric and magnetic fields (E and B). Participants explore the implications of this choice in both classical and quantum contexts, including the breakdown of canonical approaches when using E and B.
  • Some participants argue that the Aharonov–Bohm effect demonstrates the physicality of potentials, while others contend that in classical physics, E and B fields suffice to describe systems.
  • One viewpoint suggests that the use of potentials in Lagrangian mechanics is analogous to the use of mechanical potential in classical mechanics, as it relates directly to energy and does not involve spatial derivatives.
  • Another participant highlights that gauge invariance leads to the necessity of using potentials, as different potentials can yield the same fields, complicating the interpretation of potentials as "real."
  • Some contributions emphasize that the canonical approach reveals phi as a non-dynamical variable, while A corresponds to the electric field E, raising questions about the roles of coordinates and momenta in the fields approach.
  • There is a discussion about the formulation of the Lagrangian in terms of E and B, with some asserting that it is possible to construct a Hamiltonian formalism based on these fields.
  • One participant notes that Maxwell's equations, expressed in terms of potentials, allow for a Lagrangian that yields the correct equations upon variation, emphasizing the relationship between potentials and the Lorentz force.
Participants express multiple competing views regarding the use of potentials versus fields in the Lagrangian formulation, with no consensus reached on which approach is definitively superior or more fundamental.
Some discussions touch on the limitations of gauge invariance and the implications of non-locality in the interpretation of potentials versus fields, but these aspects remain unresolved.
Rocky Raccoon
What's the most persuasive argument for using the potential phi and A as independent deegres of freedom in the electromagnetic Lagrangian instead of the more physical field E and B? Why does the cannonical approach break down for E and B?
The Aharonov–Bohm effect proves that the potentials are physical quantities.
However, it is a quantum effect, and I think that in the pure classical domain, only the E and B fields are necessary to describe the behaviour of any physical system.
In quantum mechanics, although a particle might feel no field at all in the experimental setup, it can "feel the potential".
See the site below, or many other sites, explaining this Aharonov–Bohm effect in detail.
I have always been impressed that nearly 200 years ago, physicists have been able to identify a peculiar structure in classical mechanics (Lagrange, Hamilton) that is deeply related to quantum mechanics. So true that the Lagragian formulation is the 'shortest path' to quantum mechanics and the Aharonov-Bohm effect more specifically. Amazing!
See for example:
http://www.applet-magic.com/bohm.htm
http://www.weylmann.com/aharonov.pdf
The same reason we use potential in classical mechanics--Lagrangian mechanics is the variational calculus of Energy. Mechanical potential (V/m) relates directly to potential energy (just multiply by the mass), while the force F has a spatial derivative built into it, so F just doesn't work in Lagrangian. This is the exact same relationship that Phi and A have to E and B (or more completely, D and H).
This is misleading for a couple reasons. In general, under a gauge transform, A and phi can be changed and leave the E and B fields unchanged. Yet the Aharonov-Bohm effect is gauge invariant. This implies that we cannot deduce the value of A from the AB experiment, and actually, from the form of the quantum Hamiltonian, from any experiment.
We can glean no more information than is already contained in the fields. In particular, the AB effect can be written entirely in terms of the magnetic field (specifically, the magnetic flux modulo some fundamental flux constant).
The only reason to favor the interpretation of the potential as "real" and not the fields is the field interpretation implies non-locality. Since the AB effect takes place in a static B field, we have no right to complain about nonlocality because the information has had time to propagate from the B field to everywhere in space. Even if we were to complain about nonlocality and therefore adopt A and phi as real, in E&M, A and phi are not necessarily local (c.f. Coulomb gauge).
Perhaps it is the case that A and phi are somehow more real than E and B, but the AB experiment certainly doesn't prove it.
Rephrasing your question in geometrical terms, I say: Why is a connection more fundamental than curvature ? Because curvature comes from connection and not connection comes from curvature. That's the story in geometry.
You can write down the E-m lagrangian in terms of E&B (D and H) and build the Hamiltonian formalism on it without any problem, too.
The E-m potential captures the gauge freedom of the theory. We know that dF=0. For a cute manifold as flat Minkowski space-time, the de Rham cohomology is trivial and so we end up with F=dA. But that automatically leads to gauge invariance. Different potentials could give the same field. So even starting with F will eventually force you to use A and encounter gauge invariance.
The potential becomes fundamental at quantum level, where gauge invariance really intervenes. Actually, in QFT one can show that the e-m field's consistent couplings with matter occur only through the potential and not through its curvature.
Can you provide a reference for this?
In the canonical (potential) approach, phi turns out not to be a dynamical variable, while a canonical momentum corresponding to A is electric field E. What are the "coordinates" and their respective momenta in the fields approach?
How would you couple these fields to matter? Phenomenologically, we require things to couple through a four current, and so we need a four vector to which we can couple the current. Otherwise, we can't make a lorentz invariant action.
Every theory that is based on a least action principle that I know of assumes that the Lagrangian depends on at most, first derivatives of the field. When we perform a variation, we get equations that involve second derivatives of the field. Maxwell's equations involve only first derivatives with respect to the electric and magnetic fields. Keeping in mind that the electromagnetic fields are expressed as first derivatives of the electromagnetic potentials, it means that maxwell's equations are second order equations with respect to the potentials. Then, one can formulate a Lagrangian which gives an action, which, upon varying with respect to the the potentials, not the fields, gives the proper Maxwell's equations.
Then, if you write the Lorentz force acting on a point charge in terms of the potentials:
[tex] \mathbf{F} = q \left[-\frac{1}{c} \frac{\partial \mathbf{A}}{\partial t} - \nabla \Phi + \frac{1}{c} (\mathbf{v} \times (\nabla \times \mathbf{A}))\right][/tex]
Then, using the double crossed product formula:
[tex] (\mathbf{v} \times (\nabla \times \mathbf{A})) = \nabla(\mathbf{v} \cdot \stackrel{\downarrow}{\mathbf{A}}) - (\mathbf{v} \cdot \nabla) \mathbf{A} = \nabla(\mathbf{v} \cdot \mathbf{A}) - (\mathbf{v} \cdot \nabla) \mathbf{A}[/tex]
and the fact that the total time derivative:
[tex] \frac{d \mathbf{A}}{d t} = \frac{\partial \mathbf{A}}{\partial t} + (\mathbf{v} \cdot \nabla) \mathbf{A}[/tex]
we can write the Lorentz force as:
[tex] \mathbf{F} = \frac{d}{d t}\left(-\frac{q}{c} \mathbf{A}\right) - \nabla\left[q \left(\Phi - \frac{1}{c} (\mathbf{v} \cdot \mathbf{A})\right)\right][/tex]
Then, if we introduce a generalized potential:
[tex] U = q \left[\Phi - \frac{1}{c}(\mathbf{v} \cdot \mathbf{A})\right][/tex]
[tex] \mathbf{F} = \frac{d}{d t} \frac{\partial U}{\partial \mathbf{v}} - \nabla U[/tex]
So, the force is expressible through a potential of the form as the Lagrange's equations. This potential enters in the Lagrange function for the particle in an external electromagnetic field. As you can see, this potential energy is expressible in terms of the electromagnetic potentials.
Finally, according to QFT, the electromagnetic potentials form a 4-vector of a gauge field of the local U(1) symmetry.
  • · Replies 24 ·
10K
