EM Shielding Dilemma: Understanding Transverse Wavelengths
The discussion revolves around the concept of electromagnetic (EM) shielding, particularly in relation to the relationship between the wavelength of EM waves and the size of grid openings used for shielding. Participants explore the implications of transverse wavelengths and boundary conditions in the context of shielding effectiveness.
  • One participant notes that while the classical picture of EM waves specifies wavelength along the direction of travel, the concept of a transverse wavelength arises in the context of EM shielding with grids, leading to a dilemma regarding its definition.
  • Another participant explains that the fields of an EM wave are transverse to the direction of propagation, and discusses how a screen of vertical wires can act as a polarizer, blocking certain components of the electric and magnetic fields while allowing others to transmit.
  • A different participant raises confusion about the relationship between wavelength and grid hole size, suggesting that the minimum spot size of radiation may affect the effectiveness of shielding, and proposes a scenario where a beam with a wavelength equal to the hole size could still penetrate the shielding under certain conditions.
  • Another contribution discusses boundary conditions and how grid spacing relates to the lowest mode supported by the grid, explaining that if the wavelength is lower than twice the grid spacing, there may not be a propagating mode through the grid, although radiation could still transmit as an evanescent mode with attenuation.
  • A later reply expresses gratitude for the clarification regarding the waveguide analogy in understanding shielding, indicating a positive reception to the technical explanations provided.
Participants express varying levels of understanding and confusion regarding the concepts discussed, and while some explanations are appreciated, there is no consensus on the relationship between wavelength, grid size, and shielding effectiveness. Multiple competing views and interpretations remain present in the discussion.
Limitations include the dependence on specific definitions of terms like "transverse wavelength" and "evanescent mode," as well as unresolved mathematical relationships between wavelength and grid dimensions.
invisigo
In the classical picture of an electromagnetic wave, the wavelength is specified along the direction of travel. However, with EM shielding that is using a grid (microwave, chicken wire), I've heard that so long as the spaces are less than the wavelength, you will achieve electromagnetic shielding. This description implies that there is a transverse wavelength to a EM wave that is "blocked", but in our classical picture, we never defined a transverse wavelength.
Can anyone explain this dilemma or propose a physical picture that works?
The fields are transverse to the direction of propagation. The tangential electric field and the normal magnetic field are canceled out along the surface of a perfect conductor. If we have a screen of vertical wires (not a grid, but just along one direction), then what will happen is that the component of the electric field along the wires and the magnetic field perpendicular to the wires will not propagate through the screen as they will be canceled out. However, the component of the electric field normal to the wire and the magnetic field tangent will transmit through. Hence, you have a polarizer. So a mesh are two polarizers at right angles, each one will remove one of the two polarizations that the field can be decomposed into (the wave can be polarized in any direction in the plane perpendicular to the direction of propagation but it can always be decomposed into the summation of two polarizations) and thus it will prevent the transmission of an arbitrary field.
The idea I'm more confused about is the relationship between wavelength and the grid hole size. One idea I just thought about is maybe it has to do with the minimum spot size of the radiation. If this is the case, then the rule of thumb for hole size does not hold exactly. I can get a beam with wavelength 1m into shielding with holes of 1m just by increasing my aperture.
Since spot size d = focal length*wavelength*3.83 / pi*aperture diameter
Then a focal length of 50meters and a aperture diameter of 100meters would allow me to get through your EM shielding designed to block 1m waves.
It has to do with the boundary conditions. The grid spacing is indicative of the lowest mode (and wavelength) that can be supported in the grid. The grid will always have a finite amount of depth, and so you can do a very crude analysis by treating a single grid element as a rectangular waveguide. In this case, we know that the tangential electric field and the normal magnetic field must go to zero on the surface of the conductor (assuming PEC). All of the fields must be zero inside the conductor, past the surface. So the boundary conditions are the zeroing of certain components on the surface for wave solutions. The result is that the components of the wave in the plane parallel to the grid must be sinusoidal and thus the lowest mode is going to be of a wavelength twice the distance between the edges of the grid.
If the electromagnetic wave has a wavelength lower than around twice the grid spacing (normally we choose 1/4 wavelength spacing), then there will not be a supported propagating mode through the grid. The radiation will still transmit through because it will travel as an evanescent mode, but it will be severely weakened. The degree of this attenuation will be dependent upon the thickness of the grid's wire and the spacing of the grid in comparison to the incident wave.
Ah! Yes, thank you for the clear explanation! I never thought to think of shielding as a waveguide, but it makes perfect sense now! I am indebted to you for this insight.
  • · Replies 51 ·
10K
  • · Replies 26 ·
9K
11K
  • · Replies 131 ·
27K
