Proof of EM Wave Orthogonality: Ideas Needed
  • Context: Graduate
  • Thread starter Thread starter dave4000
    Em Em wave Wave
The discussion focuses on proving the orthogonality of the electric field (E), magnetic field (B), and the direction of propagation (k) in electromagnetic waves. The equations provided, E=E_{0}e^{i(k \bullet r - \omega t)} and B=B_{0}e^{i(k \bullet r - \omega t)}, illustrate the relationship between these vectors. The participants emphasize the use of plane waves for simplification and discuss the Poynting vector (S=E x H) as a measure of power flow direction. The conversation also clarifies that the wavenumber (k) is a scalar, while the vector \vec{k} indicates the direction of propagation.
  • Understanding of Maxwell's equations, specifically curl operations.
  • Familiarity with electromagnetic wave equations and their representations.
  • Knowledge of vector calculus, particularly in relation to cross products and dot products.
  • Basic concepts of coaxial cables and their electromagnetic properties.
  • Study the derivation of Maxwell's equations in both integral and differential forms.
  • Learn about the Poynting vector and its significance in electromagnetic theory.
  • Explore the differences between plane waves and spherical waves in electromagnetic propagation.
  • Investigate the role of directional couplers in measuring electromagnetic signals in coaxial cables.
This discussion is beneficial for physics students, electrical engineers, and researchers in electromagnetic theory, particularly those focused on wave propagation and field interactions in various media.
dave4000
So I am trying to work through the proof why why the direction of proporgation, the E field and B field are all orthogonal to one another.
What i have is...
E=E_{0}e^{i(k\ \bullet \ r-\omega t)}
B=B_{0}e^{i(k\ \bullet \ r-\omega t)}
\nabla \times E= -\frac{dB}{dt} \Rightarrow k \times E_{0}= \omega B_{0}
\nabla \times B= \mu_{0}\epsilon_{0}\frac{dE}{dt} \Rightarrow k \times B_{0}= \mu_{0}\epsilon_{0}\omega E_{0}
and i can see from this why k, B and E must be orthogonal. What I am having difficulty with is how to get from the left to the right...
Any ideas?
Any ideas?
It is interesting and very useful to think about two signals passing one another in a coax cable (e.g., RG-8) without interference. I show cartesian coordinates below, but in a coax, E is radial, and H is azimuthal. Also, for RG-8, E/H = 50 ohms
Ex = E0 exp[j(k z - w t)]
Hy = H0 exp[j(k z - w t)]
and
Ex = E0 exp[j(-k z - w t)]
Hy = -H0 exp[j(-k z - w t)]
So one pulse goes from left to right, and the other from right to left, without a "collision". There are instruments (directional couplers) that can measure the amplitude AND direction of each pulse simultaneously.
Edit: changed k x to k z four places
You mean how to work out the derivatives?
What i have is...
<snip>
Any ideas?
Have you tried taking a dot product?
Edit- I just noticed the form you wrote for E and B- spherical wavefronts. That can complicate the maths, so it's easier to use plane waves.
For a plane wave, we can use the vector identity (ignoring any currents J)
div(E x H) = H curl E - E curl H
= -E dD/dt - H dB/dt = -1/2 (d/dt)(e0E2 + u0 H2). (= energy loss per meter). So
S= E x H is a vector (called the Poynting vector), whose direction is the direction, and magnitude is the average power flow, in watts per square meter. Both E and H are orthogonal to direction of power flow.
Actually, the OP is using plane waves (and just not specifying the direction of propagation in Cartesian coords, explicitly). Spherical waves have a much more complicated form.
What i have is...
Any ideas?
If you are having trouble working out the derivatives, it will help you to look at my responses to question 2. in this thread since you are essentially both trying to work out the same curls...Are you also having trouble with the time derivatives?
That thread has proved helpful - i have cracked the derivatives. Thanks.
Another question though, k is the wavenumber right? Is the wavenumber equivalent to the direction of proporgation?
I mean, from the solution k, E and B must be orthogonal, but how does this relate to the direction of proporgtaion?
You're welcome!:smile:
The scalar k is the wavenumber, the vector \vec{k} which appears in your plane waves (it's a good idea to get into the habit of explicitly writing vectors with some sort of marking to distinguish them from scalars!) , is defined as the product of the wavenumber with the unit vector in the direction of propagation. In other words, \vec{k} points in the direction of propagation and its magnitude is the wavenumber.
  • · Replies 39 ·
  • · Replies 0 ·
9K
  • · Replies 18 ·
