EMI - induced current on two parallel wire
7 replies · 10K views · last reply
jewhitmo
I would like to quantify the EMI on a circuit and I am confused on how to do that. I have two parallel wires that are laying on top of each other. I have tried to calculate the flux linkage and came up with:
[tex]\Lambda[/tex] = [l*[tex]\mu[/tex]o*I/(2pi)]*ln((d-a)/a)
where a=radius of each wire, d=distance between the center of the wires, l=length of the wires, I=current on wire 1, and [tex]\mu[/tex]o*=permeability of free space.
I don't understand how this would induce a current on wire 2 though.
I'd really appreciate any help with this issue.
Thanks,
J
A constant current will not induce a current in another wire; induced current is proportional to the change in the original current.
Thank you for your reply. You are right. I'm sorry I forgot to indicate that the problem is occurring because inrush current. So, there would be a change in current. Do you know how to calculate the change in current on wire 2 due to a change in current on wire 1?
It depends on how exactly the current is changing. You don't necessarily need a change in current; a change in magnetic flux through some pre-defined surface or where magnetic flux lines are being cut suffices as well.
If I could measure exactly how the current is changing on wire 1 do you know how I would be able to calculate the change in current on wire 2? Does the flux linkage equation apply here? If so, how does it translate into a change in current on wire 2?
Thanks!
You have to use Faraday's law here:
[tex]Emf = -\frac{d\Phi_B}{dt}[/tex].
So this gives you the induced emf on wire 2. To get the induced current, divide emf by resistance of wire 2. That's all I can say if you don't provide any more information on the setup.
You can have both inductive and capacitive crosstalk. The capacitive crosstalk is just coupling from wire-to-wire. Inductive coupling requires tso loops to couple the energy. So don't ignore the return paths of the wires in your inductive crosstalk calculation.
