Emission of Gamma and Beta rays : Experimental Problem
The discussion revolves around an experimental problem involving the emission of gamma and beta rays from cylindrical sources and the observed deviation from the expected inverse square law in the counting of these emissions using a GM counter. Participants explore the implications of geometry on the emission patterns and the counting results.
  • Experimental/applied
  • One participant notes that the inverse square law applies to point-like sources, suggesting that the cylindrical shape of the source may affect the results.
  • Another participant emphasizes the importance of the geometry involved, questioning the separation distance relative to the source size.
  • A participant explains that at close distances, fewer hits are observed than predicted by the inverse square law due to the non-pointlike nature of the source and detector.
  • One participant presents a mathematical model involving integrals to describe the relationship between hit counts and distance, indicating that the slope approaches -2 at larger distances.
  • Another participant requests clarification on the derivation of the integral presented, linking it to the concept of solid angles and isotropic emission.
  • A later reply challenges the proportionality of the integral to N, suggesting it should be log(N) instead, leading to a discussion on the nature of the relationship between counts and distance.
Participants express differing views on the applicability of the inverse square law to cylindrical sources, with some agreeing on the need to consider geometry while others debate the mathematical implications of the results. The discussion remains unresolved regarding the exact nature of the relationship between hit counts and distance.
Participants highlight the limitations of their analysis, including the dependence on the geometry of the source and detector, the effects of distance relative to source size, and the assumptions made about isotropic emission.
EsPg
Hi there!
The experiment: I'm counting Gamma and beta rays emitted from gamma and beta cylindrical sources, for counting I'm using a simple GM counter, which has nearly the same cylindrical shape (i mean diameter).
As we all know this are electromagnetic emissions, so they distance must obbey an inverse square law.
The problem: When I make the analysis of the data i don't get a -2 in the power of the distance, but a -1.48 exactly all the times. I'm guessing the problem is that the inverse square law applies for puntual emission, not for a "cylindrical" emission, as the one I'm using.
¿How can I solve the problem? I'm trying to get some geometrical factor that might let me get the inverse square law, but I'm not sure. If anyone knows, i'd love to listen.
P.D.: Greetings from Colombia
You need to more specific about the geometry involved. What is the shape of the source? How far apart are the source and detector? The inverse square law will hold if the separation distance is large compared to the size of the source.
Further question: the attenuation (particularly of beta) due to the atmosphere, assuming the space between source and dectector is simply air.
Thanks for your interest.
For the source imagine a coin, only one side of the "coin" radiates. The detector has an opening of aproximately the same radius as the source. The distance varies from 1cm to 15cm more or less. I think this distances can't be taken as large compared to the source, since the diameter of it it's around 4 cm.
You don't get inverse square law exactly, because your source and your detector are not pointlike and their dimensions are comparable with the distance between them. At close distances, you get fewer hits than predicted by inverse-square law.
If you plot log of hit count against log of distance, with perfect pointlike source and detector you'd get a straight line with a constant -2 slope (n = c*x^-2, therefore ln n = ln c - 2 ln x). With real-life equipment you get a curved line whose slope approaches -2 for high distances.
For an isotropic, homogeneous flat disk source and a perfectly efficient flat disk detector, coaxial and parallel to each other, the dependence should look like this
[tex]N \propto \int_0^r \int_0^r \int_0^{2 pi} \int_0^{2 pi} r_1 r_2 dr_1 dr_2 d\phi_1 d\phi_2 h / (h^2 + r_1^2 + r_2^2 - 2 r_1 r_2 cos (\phi_1 - \phi_2))^{1.5}[/tex]
where h is the distance between disks. Does not look like it evaluates analytically (not to me anyways - you can eliminate one of [tex]\phi[/tex] and that's about it), but numerical calculation confirms your slope ~-1.5 when h ~ r.
Thank you, great answer. I haven't calculate the integral, but i believe you. Thanks again.
Hamster, could you elaborate a bit on how you got to that integral? The denominator looks a bit like the cosine law.
For any point (r1, phi1) on the surface of the emitting disk, what's the share of total radiation emitted by the vicinity of that point that ends up hitting the detector? If we assume that the emitter is isotropic, it's equal to the solid angle subtended by the detector disk at that point. To calculate the solid angle, we write down double integral over the surface of the detector. Solid angle subtended by an element of the detector (r2,phi2 ... r2+dr2, phi2+dphi2) is
[tex]r_2 dr_2 d\phi_2 cos(\theta) / l^2[/tex]
where l is the distance between (r1, phi1) on the emitter and (r2, phi2) on the detector, and [tex]\theta[/tex] is the angle between l and a normal to the surface.
[tex]cos(\theta) = h/l[/tex]
[tex]l^2 = h^2 + (r_1^2 + r_2^2 - 2 r_1 r_2 cos(\phi_1 - \phi_2))[/tex]
Thanks, guy. Nice piece of analytical work.
Yeah, that was great. Just one thing, I think it's not N what is proportional to the integral, but log(N). Please correct me if I'm wrong.
What makes you think that?
If you get only N, then you'd be saying that there is a lineal relation betwwen thenumber of counts and the distance. With log(N), the relation would be exponential, as it is.
