Maximizing Height and Final Velocity on a Tilted Rough Surface
  • Thread starter Thread starter hastings
    Dynamics Energy
The discussion focuses on solving a physics problem involving an object moving up a tilted rough surface with a dynamic friction coefficient (µd) of 0.3 and an angle (α) of 30°. The maximum height (h) reached by the object is calculated to be 30 cm, while the final velocity (vf) upon returning to the starting point (P0) is determined to be 1.69 m/s. The solution employs the conservation of mechanical energy and accounts for work done against friction.
  • Understanding of conservation of mechanical energy principles
  • Familiarity with dynamics and kinematics
  • Knowledge of friction forces and coefficients (static and dynamic)
  • Ability to apply trigonometric functions in physics problems
  • Study the application of conservation of energy in non-conservative systems
  • Learn about the effects of friction on motion in inclined planes
  • Explore advanced dynamics problems involving multiple forces
  • Investigate the relationship between potential and kinetic energy in various contexts
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to enhance their understanding of energy conservation and friction in motion scenarios.
hastings
An object passes through point P0 in the instant t=0, going up with a velocity v0=3m/s along a tilted rough surface (dynamic friction coefficient µd=0.3) which forms an angle α=30° with the "ground". The length L of the slanted surface is practically endless.
Find
a)h, the maximum height the object can reach
b)vf, the final velocity when the object re-passes through point P0 assuming that the static friction coefficient, µs, is such that the object doesn't stop when it reaches the maximum height.
Note: This problem can be solved either by applying the 2nd dynamics principle or through energetic deductions.
[Answers: a) h=30 cm ; b) vf=1.69 m/s]
K(B)+U(B)= K(A)+ U(A) (kinetic energy and potential energy)
F=µ∙N (friction force, a non-conservative force)
W=⌠F∙ds (work as integral of force and movement)
I tried to solve the first question, find h , through the conservation of mechanical energy. I called B the point of max height, A=P0 the starting point.
E(B)=E(A) - Work(A→B)
½m∙v²(B)+mgh=½m∙v²(A) - F∙L
where F is the friction force, a non-conservative force: F=µd∙N=µd∙(mg∙cos(30°)).
But now how do I continue? L is ∞, and I don't know v(B). should I assume v(B)=0 in order to solve the 1st question? Is what I have done till this point, right?
the picture of this problem is a bit confusing so I'm sending you a copy just as it is on the paper.
a) at max height, kinetic energy = 0.
displacement along the incline is d = h/sin(30). so, d = 2h
initial kinetic energy - work done by friction = final potential energy
(1/2)m(vo)^2 - u*mg*cos(30)*2h = mgh ... solve for h.
b) once you determine h from part (a) ...
initial potential energy - work done by friction = final kinetic energy
mgh - u*mgcos(30)*2h = (1/2)m(vf)^2 ... solve for vf.
yeah, I figured it out. Thank you very much for replying!
  • · Replies 17 ·
  • · Replies 33 ·
  • · Replies 42 ·
