Why does the equation E=m*c2 not require any condition of matter?
The equation E=mc² does not require specific conditions of matter because energy can be derived from mass in various states, as illustrated by two cases involving hydrogen and oxygen, and boiling water. In the first case, the reaction of hydrogen and oxygen to form water releases 572 KJ of energy, while direct conversion of the gases yields only the mass-energy equivalent without this additional energy. In the second case, extracting energy from boiling water results in a higher energy output compared to direct conversion of the same mass of water at zero degrees Celsius. The concept of mass deficit, related to binding energy, explains the differences in energy output.
  • Understanding of E=mc² and its implications in physics
  • Basic knowledge of chemical reactions and energy release
  • Familiarity with concepts of mass deficit and binding energy
  • Knowledge of thermodynamics, particularly phase changes of water
  • Research the concept of mass deficit and its significance in nuclear reactions
  • Study the principles of binding energy and its applications in chemistry
  • Explore thermodynamic calculations related to phase changes of water
  • Learn about energy transformations in chemical reactions and their efficiency
Students of physics and chemistry, educators explaining energy concepts, and professionals in energy research and engineering.
suhagsindur
This is question about equation E=m*c2. Why this equation does not required any condition of matter?
Case 1: I take two mole (4 Kg)H2 & one mole(32 Kg)O2 & make water & get energy.
2H2 (4 Kg Hydrogen)+O2 (32 Kg Oxygen)=2H2O(36 Kg of water)+ 572 KJ Energy
Now I convert this water into energy by equation E=m*c2.
Total energy I get is QTotal= (36*c2) + 572 KJ Energy.
»»» Now instead of I convert hydrogen & oxygen into water, I directly convert both gases into energy so total Energy I getting is,
QTotal= m*c2 =(36*c2) Only.
This energy is lesser as compared to first one by amount of “572 KJ Energy”.
Case 2: I have one Kg of boiled water at 100 degree centigrade.
Now I extract 418.7 KJ energy from the water & make it of zero degrees centigrade.
Water at 100 C - 418.7 KJ Energy =Water at 0 C.
Now I convert this zero degree water into energy,
Total energy I getting is,
QTotal=1*c2+418.7 KJ energy
»»» Now I directly convert boiling water into energy,
I getting energy is
QTotal=m*c2=1*c2.
This energy is lesser as compared to first one by amount of “418.7 KJ Energy”.
Why it is occurs? Why energy librated is different for the same initial & final condition of mass?
Actually, you will get only 35.9999999999936 kg of water. Everything else then works out fine. This difference in mass between the products and the reactants is called the mass deficit and is closely related to the binding energy. See: http://en.wikipedia.org/wiki/Binding_energy. The mass deficit occurs for all interactions, although as you can see above it is usually pretty small and only noticeable for very strong interactions, like those involving the strong nuclear force.
This means that boiling water possesses higher mass then cold water by extremely small amount which is neglected for practical purpose.
OK, Thanks for giving answer.
  • · Replies 31 ·
  • · Replies 53 ·
  • · Replies 23 ·
  • · Replies 75 ·
