Energy created by a balloon released underwater
The energy generated by a balloon released underwater can be calculated using the formula Kw=(Mass of Water per cubic Ft)*(Gravity)*(Depth2 - Depth1). For a balloon with a volume of 3 cubic feet inflated at 100 psi and released from a depth of 200 feet, the energy produced during a 100-foot ascent is approximately 1,038.96 Watts. This calculation assumes no energy loss due to water flow, heat, or sound. The energy produced is directly related to the difference in water height displaced by the balloon.
  • Understanding of basic physics concepts such as energy, force, and buoyancy
  • Familiarity with units of measurement including Watts, pounds, and cubic feet
  • Knowledge of fluid dynamics, particularly regarding buoyancy and displacement
  • Basic mathematical skills for applying formulas and unit conversions
  • Research the principles of buoyancy and Archimedes' principle
  • Learn about energy conservation in fluid dynamics
  • Explore the effects of pressure on buoyancy in different fluids
  • Investigate the relationship between depth and pressure in underwater environments
Engineers, physicists, scuba divers, and anyone interested in underwater dynamics and energy calculations related to buoyancy and fluid mechanics.
ceej
How much energy (Watts?) would be created by a balloon that was released under water? I am picturing a scuba diver's inflatable vest (a BC) that is suddenly inflated (assume zero air inside to begin with). Or more accurately if you have ever seen a free-diver who swims down a few hundred feet and then inflates the balloon that rockets them back up to the surface. In both cases, compressed air is released into a balloon-like vessel all at once. Assume the following:
Depth released: 200ft below sea level
Length of travel: 100ft (stops 100ft below surface)
Volume of balloon: 3 cubic ft
Balloon holds this 3 cubic ft of air at 100psi so it will inflate at 200ft- assumed .5psi per ft. (don't know if this is relevant)
I am interested in how much energy is generated in the 100ft of travel towards the surface. Does the energy increase in direct relation to the length of travel or along some sort of a curve? A formula would be great so I could input different numbers. Thanks in advance for the help!
Hi.
Mass of that volume of water * g * ( depth2 - depth1 ), I think.
Regards.
Thanks, Springs. I take it that is the volume of water displaced by the balloon (ie 3 cubic ft)?
If it is the volume displaced then:
Kw=(62.4 lbs/cu ft*volume)*(9.8m/s^2)*(Depth2 - Depth1)Kw=(187.2 Lbs)*(31.36 FT/s^2)*(200ft-100ft)
Kw=587,059 Ft Lbs/Sec^2
Kw=766.19 Ft Lbs/Sec
Kw=1.039
Watts=1038.96
Correct?
Also, that formula seems to say to me "energy produced by a volume of water free falling a given distance" as opposed to the same volume of air floating a given distance through water, but I am certainly a novice. What is the theory there?
Hi.
Unit of the last formula is
Kw=587,059 Lbs Ft^2 /Sec^2
By multiplying the constant ratio of 1kg/1Lbs * (1m/1Ft)^2 , this will give Joule = Watt sec , MKSA unit of energy.
You are right. the difference of heights of water ( or minus water mass excluded by the balloon ) generates kinetic energy of balloon.
Some approximations done are
- weight of balloon including air was neglected to zero. You should replace water mass to the mass difference of water and balloon in the formula for correction.
- there is no water flow, heat, sound or any other energy dissipation by motion of balloon.
Regards.
I'm sure this is well understood by the OP and Sweet, but for others keep in mind that the total energy gained is less than the total energy required to enable the event.
Deleted post which didn't make much sense!
11K
  • · Replies 16 ·
11K
  • · Replies 17 ·
  • · Replies 27 ·
11K
