Energy dissipated through resistor
  • Thread starter Thread starter hopkinmn
    Energy Resistor
The discussion focuses on calculating the energy dissipated through resistor R3 after a switch is opened in a circuit involving a capacitor. The user correctly determined the potential difference across the capacitor and the energy stored in it after the switch had been closed for a long time. However, confusion arose when attempting to calculate the energy dissipated through R3, as the user initially did not account for the discharge through both resistors R2 and R3. The correct approach involves integrating the power expression while considering the combined effect of both resistors on the time constant. Ultimately, the user clarified their understanding with assistance, leading to a resolution of their confusion.
hopkinmn
The problem first asks to find potential difference across the capacitor after the switch has been closed a long time. Then it asks to determine the energy stored in a capacitor when the switch has been closed for a long time. I got both these answers right, with Vcapacitor=2.22V and Energy in capacitor=4.9284*10^-6 Joules.
The last part asks to determine how much energy has dissipated through R3 after the switch has been opened.
I know that Power(P)=Current(I)*Voltage(V)=(delta charge)/(delta time)*V and that Power is the derivative of Energy. However, no charge is provided and no time is provided (we just know that it's been a long time), so I'm not sure how to go about solving this problem.
The right answer for the energy dissipated through R3 is 1.41*10^-6 Joules
There are several related expressions for the (instantaneous) power dissipated in a resistor. One involves the current through the resistor, the other the voltage across the resistor.
If you can write the equation for the voltage across the resistor w.r.t. time, then you'll be in a position to use one of those expressions for the power.
So I set up the expression P(t)=V(t)^2/R3, where V(t)=V*e^(-t/(R3*C))
When I integrate this expression, I get E(t)=-.5*V^2*C*e^(-2t/(R3*C))
Since the switch has just been opened, t=0.
I then get E(0)=-.5*V^2*C
But this just gives me the same answer for part B, where I found energy stored in the capacitor when the switch has been closed for a long time. I'm not sure what I'm doing wrong.
One small problem. When the capacitor discharges it does so through both resistors R2 and R3. So the time constant must reflect that.
Ok, I understand it now, thanks so much!
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 16 ·
  • · Replies 62 ·
