genericusrnme
- 619
- 2
2. Calculate the energy distribution of the free particle
(a) in one dimension,
(b) in two dimensions,
Use (3-12) to calculate the energy distribution of the state, assuming
(a) V(r) = + K r2
(b) U f r ) = - Z e 2 / r
(3-12);
[itex]L^3 g(\epsilon) = \frac{1}{\hbar ^3} \int d^3x \ d^3 p \ \delta( \epsilon - \frac{p^2}{2m} - U(x))[/itex]
g is the distribution and L is the length of some container
For part 2a) I'm getting [itex]g(\epsilon) = \sqrt{\frac{2m}{\epsilon}}[/itex] which I'm pretty sure is wrong since surely the distribution shouldn't be inversely proportional to the energy..
I arrived at this result by using [itex]\delta( f(x)) = \sum_i \frac{\delta(x-x_i)}{|f'(x_i)|}[/itex] where the xi's are the roots of f(x), I'm pretty sure this is correct so really I'm not sure where I went wrong.
I'm also not sure how to work with the dirac delta when I'm integrating over more than one variable like this, for example in the two dimensional case I'd have (leaving out constants) [itex]\int d^2p \ \delta(e - p^2) = \int d^2p \ \delta(e - p_x^2 - p_y^2)[/itex] and I don't really know (or perhaps remember, it's been about a year since I last looked at a dirac delta) how to deal with this.
This 'energy distribution' thing is kinda confusing me too, the first mention of it is in regards to a particle in a box with all the [itex]n_{x,y,z}[/itex]'s describing the energy and the distribution is given as (again, leaving out constants)
[itex]L^3 g(e) = \sum_{n_{x,y,z}} \delta(e - n_x^2 - n_y^2 - n_z^2)[/itex]
which then goes to an integral
[itex]L^3 g(e) = \int d^3n \ \delta(e - n_x^2 - n_y^2 - n_z^2)[/itex]
and then to an integral over p
[itex]L^3 g(e) = \int d^3p \ \delta(e - p^2)[/itex]
[itex]L^3 g(e) \ \alpha \ \sqrt{e}[/itex]
(as of writing this I realize that if this is correct then I was wrong in what I wrote about the dirac delta earlier)
So I'm not exactly sure what this energy distribution is supposed to be nor am I sure how to work with these dirac deltas over functions of more than one variable.
Thanks in advance!
