How much energy does wind contribute to the Earth's atmosphere?
  • Thread starter Thread starter Kmenex
    Energy
The discussion centers on quantifying the energy contribution of wind to the Earth's atmosphere, specifically through the movement of high and low pressures. Participants highlight that most wind energy is dissipated as frictional heat rather than performing physical work. A suggested method for estimating this energy involves calculating the mean wind speed, squaring it, and multiplying by half the mass of the atmosphere. Additionally, it is noted that a tropical cyclone can release between 50 to 200 exajoules of heat energy per day, providing a basis for scaling this estimate to the entire atmosphere.
  • Understanding of atmospheric pressure systems
  • Familiarity with energy units such as joules and petawatts
  • Knowledge of basic physics concepts, particularly kinetic energy
  • Experience with meteorological data analysis
  • Research the calculation of mean wind speed in meteorology
  • Explore the mechanics of tropical cyclones and their energy release
  • Investigate the relationship between wind energy and frictional heat dissipation
  • Study atmospheric mass and its implications for energy calculations
Meteorologists, climate scientists, energy researchers, and anyone interested in understanding the dynamics of wind energy in the Earth's atmosphere.
Kmenex
Energy in --> Energy Out
I'm looking at an idea exploring the nature of the atmosphere and weather patterns.
The number of variables is truly staggering.
In want to know if anyone here knows how energetic the atmosphere is in terms of wind.
It seems that wind is essentially the process of moving high and low pressures. What i am looking for is some type of quantity that averages out the amount of energy in all of the wind on Earth in a single day. So i guess you would take the amount of work done via the movement of the gases and constituents and then relate that to the "potential energy" of a day in terms of wind force.
Any suggestions?
Most of the winds energy is dissipated as frictional heat, not physical work.
I'll take that a step further: most of the wind energy that does physical work is still dissipated as frictional heat!
... or, you can look for a "mean wind speed" for the atmosphere as a whole, square it, and multiply by half the mass.
Isn't there work done in the creation of heat via friction?
EDIT: i guess that's what russ is saying...
If you're after an order-of-magnitude estimate, http://en.wikipedia.org/wiki/Tropical_cyclone#Mechanics" might do as a basis:
[A] tropical cyclone releases heat energy at the rate of 50 to 200 exajoules (1018 J) per day, equivalent to about 1 PW (1015 watt).
Just needs scaling from one storm to the atmosphere as a whole, but the other necessary stats shouldn't be hard to find.
10K
  • · Replies 69 ·
16K
  • · Replies 21 ·
22K
11K
